Question about KitchenAid Washing Machines
Water does not stop - KitchenAid Washing Machines
    Sergeant:
  • 291 Answers
Pressure switch could be faulty, but not as likely as hose to pressure switch being loose or clogged.
Posted on Jan 20, 2013
Water is filling up but dont stops and start owerfloawing.Indicator lights are ok but durinig owerfllowing lights disapiered.Float switch is ok what stops water.Is it pressure switch?Thank you.
there is a solenoid that is activated by the float switch
that solenoid cuts off the water
the unit may have a split diaphragm in it and is inoperative in stopping the water in
Oct 02, 2016 | Dishwashers
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Water would not stop running into icemaker, now
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Mar 25, 2010 | Refrigerators
Water not stopping coming out of the ice maker
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker
Nov 05, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water does not stop and will overflow
Hi, Can you get the water to stop by turning the washer off? If the water continues to fill when the power is off, you eill need to checnge the inlet valve. If the water does stop filling when the power is off to the waser, the water level switch needs to be tested.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 26, 2009 | Washing Machines
Ice machine will not stop filling with water...overflows
This sounds like a stuck water valve. Un-plug the fridge and see if the water stops flowing to the ice maker. If it stops, it's a control board (if equipped) or ice maker issue.
If not, turn the water off to the fridge, pull the fridge away from the wall, get behind it and trace the water line (small, plastic line) from the back of the fridge going down to the water valve. Remove the cover, and you may need to remove the water solenoid (the water valve) and see what happened.
Apr 27, 2009 | Refrigerators
Water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
Apr 11, 2009 | Nuova Simonelli JAZZ Espresso Machine
Water will not stop on cycle
If you turn the timer off and the water still runs you have a bad water valve. If it stops when the timer is off, You have a bad pressure switch.
Nov 19, 2008 | Frigidaire CWS3600AS Top Load Washer
Water to the Ice maker and water dispenser has stopped
check to make sure the valve is not froze if so water cant come thru
Nov 11, 2008 | Frigidaire FRS26R4A Side by Side...
Washing Machines Logo
12 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
