Question about Kenmore Elite 45986 Front Load Washer
Broken baffles I washedm some heavey duty overalls and two of the three baffles broke. Now I have to replace them. Anyone know how to get to them and place tehm in? Or do they just snap into place?
    President:
  • Kenmore Master
  • 2,651 Answers
Yes they snapp right in place, it also comes with a scrw to secure them after installing, hte screwhole is acess by reomving teh top of the unit, and from there you will see a small black rubber hose leading to the top of the tub assy( from the dispensor area) after pulling that hose out of the hole, you can spinn hte tub by hand untilk you line up the baffle hole... thea prt number for the baffle kit is 8182233
Posted on Jan 27, 2009
Baffles broke o my
Can search on Google to buy a new baffles then just slide in the new one to replace the broken part.
Oct 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Baffles broke in front loading washer
You will need the screws to hold them in and unfortunatly to do them you have to split the 2 drums apart unless you can see where the screws mount on the new baffles, but usually they screw in from the outer side of the inner drum. A lot of work for such a small part.
Dec 29, 2012 | Kenmore Washing Machines
Broke fins/tumblers
This is an easy fix. You need to pop the top of the dryer up to do so. Depending on the model you may have to take the front off (older models), or just locate the clips located on the left and right side under the lid, and with a flat head screw driver push them in and lift up. (newer models). After you have the top up, located the baffle thats broken and install. Keep in mind that if the baffle is loose its more than like the hole where the screw goes is stripped and the whole baffle should be changed.
May 29, 2012 | Maytag MDE5500AYW Electric Dryer
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Problems with starting up battery is fully charged glow plugs was new in december 09 will sometimes start with jump starter also brand new heavey duty battery last week and still wont start on occasions
Hi my name is Tom and I am here to help.
You are on the right track with a heavy duty battery. You have a diesel engine. It has a high compression. If you replace your starter with a heavy duty one, that should clear up your problem.
If I can be of further help let me know.
TomE twenslin@aol.com
Jun 23, 2010 | Cars & Trucks
Just like my dad I figured I could fix it and
you might try going to bostitch.com and typing in your model number to see if they have a parts diagram, if not give me the model number and I will see what I can do.
Dec 30, 2009 | Heavy Duty Stanley Bostich Heavy-duty...
Change one baffle only or do you need to replace all three?
No as long as the baffles are screwed in properly and no other damage is present it is not important at all.
Sep 30, 2009 | Kenmore Elite 45986 Front Load Washer
Baffle broke off
Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
Here is the link that will take you directly to the page:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
404 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
