Question about Motorola Mobility RAZR V3
Battery everytime I turn my phone on it says invalid battery and will not do anything.My daughter has the same phone and I put her battery in and it says the same thing.
  • Anonymous Apr 25, 2008
    My motorola v3 razr says "invalid battery" whenever i plug it i, and that is the only time it will work. I got a new battery and it still said the same thing. the people at motorola said that moisture was in the phone because the dot on the back was red. i asked some of my friends if the dot on theirs was red and they all said yes and their phone works fine. After about a week or two, it will finally say "charging" but it will only charge half-way and once it dies, or i turn it off, it will go back to saying "invalid battery." Any help please?
Try cleaning battery contacts with a pencil rubber. It worked out for me
Posted on May 30, 2008
I'm not sure of any solutions, but I am having the exact same problem with my phone.. i was on the phone with a friend and after i hung up about 20 minutes later i looked at my phone and it would only turn on if it was plugged in saying invalid battery.
Posted on May 01, 2008
  • 63 Answers
My experiences with that problem is that u need a new battery. Try and purchase a new one and see if that solves u r problem. did u try u r daughter's battery in u r phone ? Maybe u should...If the problem persist it's possible that u r phone might be faulty.
Posted on Jul 18, 2007
    Problem Solver:
  • 11 Answers
In my experiences invalid battery usually means that the phone is liquid damaged. You will need to get a new phone.
SOURCE:
When i start up the phone its shows invalid battery but i replaced new battery still it not works
1. connect your charger and wait about 1 hour (off position)
2.turn on your phone
3. pull out battery
4. put battery back and push battery until connect with the socket battery
5. if it doesnt work doit step (2.3.4) until show charging note
ps: it work on my motorola v6 ferrari edition
Apr 27, 2012 | Motorola Mobility RAZR V3i Cellular Phone
My grand-daughter just dropped my phone on the tile floor and when I plug it in to charge, it reads "invalid battery" Help !!
Try and take the battery ouut and make shure that the contacks inside the phone are straight and even then replace the phone and see if it works;; i hope this helps
Feb 21, 2010 | Motorola Mobility RAZR V3x Cellular Phone
The phone has froze on the nokia screen when i turned it on
turn off the 5530 first then remove the memory card then turn it onwait until it gets to the home screen then put te memory card back. it works everytime.
one thing , have you downloaded may things to your phone?
I think thats the main cause.
I had the same problem too.
Jan 06, 2010 | Nokia 5530 XpressMusic Smartphone
Keep getting download message
You may still have water in tight places due to water surface tension. Open all the access doors, take out the SIM card, battery and anything else that is removable and put all parts in a ziplock bag. Get some dessicant bags (from old shoe boxes), cardboard pieces, saltine crackers and put them in the ziplock bag also and put on top of your microwave oven (if it is used a lot) or in the window where it gets direct sunlight. Leave it there until moisture gets on the bag then disappears again (3-5days) The dry items in the ziplock will help draw out all the moisture better than air drying. I have done this many times on cell phones, gameboys, etc. and it works everytime.
May 16, 2009 | Samsung Propel A767 Cell Phone
My mobile made by LG keep saying -invalid USIM card
This has alos happened to me, I put in the wrong pin 3 times, then as it was laste and it was asking for a puk, I turned the phone off to save the battery, when I turned it back on it came up 'Invalid USIM card' is there anything that can be done?
Apr 14, 2009 | LG KU990 Viewty
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola invalid battery
Do this and see if this works
Pull out the battery when the phone is turned ON(remove the battery when the phone is working.)
wait for like 15 to 20 seconds
Put the battery again and turn the phone ON
Jun 07, 2017 | Cell Phones
Invalid battery
HI dear my motorola c261 set problem is dead set.so any prson have idea give me that perair the dead set problem...?my Email address is [email protected]
Jun 05, 2008 | Motorola Mobility C261 Cellular Phone
Invalid Battery
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
May 14, 2008 | Motorola Mobility RAZR V3
Invalid Battery
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Feb 20, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
4,575 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
