Question about Fuji FinePix S700 Digital Camera
When i put fresh AA bateries in my fuji finpix s700 the back screen starts to boot up, but then the battery light starts to blink and it tells me there is no battery power...then it shuts down. the silver metal battery contacts on both sides look a tiny bit corroded. I already tried to "scuff up" the contacts, but still no good. any advice?
  • 244 Answers
Bad contacts and bad solder joints drain batteries fast.
If your battery terminals are corroded they need to be cleaned. If moisture has corroded them then the chances are some solder joints inside the camera have been corroded too. re-solder battery terminal wires to start with.
Posted on Jan 27, 2009
  • 23 Answers
1. get new batteries. 2.try switching the batterys to + - + - or just keep switching them.welcome
Posted on Jan 26, 2009
Does the fuji S4000 camera take aa bateries?
Yes, the camera takes four AA batteries. You may use disposable alkaline or lithium batteries or rechargeable NiMH batteries. Do not use manganese or Ni-Cd batteries.
Aug 02, 2011 | Cameras
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
I replaced a broken LCD screen and now the backlight does not work, is that a setting or is there something wrong with the new screen? Fuji Film Finepix s700
Some cameras have a button to toggle the back light on and off. It is possible that the old screen damaged the back light drivers on the circuit board. It is also possible the new screen is defective. I have seen both scenarios.
Jerry G.
May 12, 2010 | Fuji FinePix S700 Digital Camera
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
Flat Batteries
I've turned many of my customers into users of the Energizer Ultimate Lithium AA batteries. Many people who have been ready to throw their camera away find the Energizers fix all their problems. Make sure to get the Energizer Ultimate Lithiums, as there are some lower output Energizers available too.
Aug 31, 2009 | Fuji FinePix S7000 Digital Camera
My fuji finpix s700 will not download pictures
down loading from a camera can be problimatic,
the easyest and cheepest and functional way to solve it is to get an external card reader and use that to transfer images
no to work on your sulution:
The basic thing to start with
remove batteries from your camera for a while
and reset your computer
test or replace the cable you are using and see how you go.
May 05, 2009 | Fuji FinePix S700 Digital Camera
Fuji Finepix s700
I recommend to all my customers with AA battery life issues to try Energizer Lithium AA's. Virtually all battery issues solved. I think alkaline batteries are being manufactured poorly, these days, so even brand new they aren't great.
Mar 08, 2009 | Fuji Finepix S9600 Digital Camera
My fuji finpix s1 will not pull up the menu, nor can I take any pictures however the automatic focus works, the function lcd lights up but it will not work either.
rdp19 did not mention the ERR msg.
I had the same problem, however after messing with it the ERR message is up.
If RDP19 gets this, did you get it fixed.  Where and what cost?
Jan 26, 2009 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S700 Who can i see my batery power on my camera
Hi - You can download the manual from the link underlined in blue below:
FinePix S700
See page 21:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 03, 2008 | Fuji Cameras
Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
Jun 12, 2008 | Fuji FinePix S700 Digital Camera
Fuji FinePix S700 Digital Camera Logo
132 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
