Question about Pass & Seymour Electrical Supplies
How do I wire a tm 813-wcc6
I'm trying to wire a single pole light and a light with two switches relatively close together ( each side of the door). How would I wire them power in from the three way switch to the light and the tm 813
  • 37 Answers
SOURCE: 3-function control switch
You are correct.
Posted on Jan 27, 2009
  • 63 Answers
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Posted on Apr 05, 2009
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Posted on May 05, 2009
  • 76 Answers
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
  • 864 Answers
SOURCE: how to wire 3 switches in a 3 gang box
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram: a5fa64a.gif
Posted on Sep 23, 2009
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
http://waterheatertimer.org/images/2-single-pole-switches.jpg
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
http://waterheatertimer.org/images/single-pole-and-3-pole.jpg
Add a comment
Jul 05, 2013 | Electrical Supplies
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
I am trying to install a Pass & Seymour Harmony fan speed control switch. It has 2 red wires and 1 black. I hooked up the power to the red line and the black leading to the wiring for the fan. No...
Are you wiring for 3-way or single pole?
In other words, are you using 1 switch (single-pole) or 2 switches (3-way)
http://waterheatertimer.org/pdf/Pass-and-seymour-3-way-3-speed-fan-control.pdf
Before installing device, separate all wires in box and turn power on and then test each wire to bare ground wire >> tester will light up on Hot power source.
Black wire on device is connected to Hot power source.
Red wire on same side of device as black wire is capped off in single pole application.
Red wire on other side of device from black wire goes to the fan motor.
Green wire is ground.
Set fan on highest speed before connecting red wire to fan, and then do not adjust fan speed using pull chain.
I am unsure what volt-amp-testing will show for power output on either red wire, but certainly it will vary as the switch is adjusted to each speed.
Call 800-223-4185 for Legrand tech support.
Sep 25, 2012 | Electrical Supplies
WIRING A SINGLE PRESET DUAL DIMMER AND FAN SWITCH
Hi *****,
I'm an electrician and can help you with this problem. First - shut off the power. Check your wiring as I describe the connections below.
If this is the only switch operating the fan and light, it should be wired as a single pole in the direction sheet. That is as follows:
1) one black wire - it should be connected to the "hot" power source, 2) one green wire - it should be connected to the bare / green ground wires & switchbox (if metal), 3) one red wire - it should be connected to the fan hot wire, 4) one yellow wire - it should be connected to the light hot wire, the remaining wires (yellow with a "3 way label" and red with a "3 way label") should not be connected to anything and capped with a wirenut.
The wiring changes if you are using a second switch to operate either the fan or light (download & view the wiring diagram provided here to follow along with my text). In this case, the hot wire from the fan or light would connect to the black screw of a standard 3 way switch, and the remaining two terminal screws on the switch would connect to the red / red with 3 way label - or yellow / yellow with 3 way label pair. Power and ground wiring on the dimmer black and green are the same as the single pole wiring described above.
I hope this helps & good luck!
Jul 08, 2012 | Electrical Supplies
I'm want to install a toggle switch/outlet but have 2 white wires and 1 black. It's a Pass & Seymour 691-WCC6 switch. Can I install this switch?
More information is needed.
Unknown what wiring device was there before, and which wires were connected to which screw terminals.
Wire color is not as important as knowing what wire is for.
If both white wires were connected together before, then they need to be put back same way.
Separate wires. Turn on power. Test each wire to bare ground. Tester lights up on Hot wire. The Hot wire is usually black.
In back of box are white wires twisted together and covered with wire nuts. These are the neutrals.
Test black hot wire to neutrals and tester will light up. If box does not have neutrals, then device cannot be installed to code.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Aug 01, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Sep 09, 2010 | Leviton 104-05611-2WS 15A Decora Single...
Light switch is off but lights stay on. Lights only turn off when breaker is off. When breaker is on, light switch in room doesn't turn lights off. Have tried several switches but none will turn power off...
If the product is as pictured, (two single pole switches in the space of a single switch), then it probably has 4 terminal screws (in addition to the ground). Look closely at the terminals on one side of the switch. If two terminal screws are brass colored and two are silver colored, look on the brass colored side. There is probably a strip of metal that connects the two terminals together - this is what is keeping your light "on". You need to move one of these wires to the other side of the switch. I assume the other switch operates OK and you only have 3 wires (besides the ground). On the other hand, if you have a total of 4 wires, then one of the wires is probably for powering something else (an outlet, or even another switch that is not supposed to be controlled by this switch). You will probably find that other device is currently being controlled by this switch. You will have to swap two wires, but without more info I can't tell you which ones.
If you found this helpful, please vote.
Feb 18, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
How do you wire a Two Single Pole Switch for each switch to run seperate lights all off of one circuit. Example: Recess Lights on one switch and a Track light on the other switch. 6 black wires, 6 white...
so 6 grounds is connected together, and conneted to mains ground (direct connection), the white wires is (mains Neutral) and you connect all 6 white wires together (to doble pole safety switch) in one end pole switch, and you connect a wire from another pole the same end at common Two Single Pole Switch and connect (Black wires recess lights) to one free pole switch and (Black wires track lights) to another free pole.
The mains connect to safety switch live (Black or Brown) to another free safety switch pole, Neutral (White or blue) to free safety switch pole and earth to ground wires on mains connector.
Note: Allways use a mains 300mA diferencial safety switch, for better protection.
Jan 02, 2010 | Computers & Internet
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
What size amp switch do I need.
NO! Use a switch rated higher in amps and equal to or higher in voltage relative to the breaker rating. Use a 40 or 60 amp switch rated a minimum 220 volts.
Feb 26, 2009 | Connecticut Electric 40 Amp 2 Pole Circuit...
Electrical Supplies Logo
245 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
