1994 astro van the alarm system will not let my vehicle start need help on how to reset or what ever the solution may be
Is this a new installation? Is this a remote starter?
If you have an alarm with a starter inhibit installed and, after disarming the system the car doesn't start, there are several steps to take to ascertain the problem.
Begin by using a voltmeter or, low voltage testlight and test the starter wire at the ignition switch. Turn the key to start and test for voltage. If you do not have 12 volts on the starter wire at the ignition switch when turning the key to start, you either have no power (battery or fuse) in the vehicle or, your ignition switch is bad.
If you have 12 volts at the switch, move your test light to the other side of the starter kill and test for 12 volts. If there is no starter kill, move your tester to the starter relay under the hood. If there is no power coming from the relay, you have found your problem. If you have power coming from the relay to the starter then test the starter when turning the key. If you have power at the starter when turning the key you have found you problem. If you have no power going to the starter when turning the key then there is break in the line.
SOURCE: I need installation guide for autopage rs-855 car alarm
I've uploaded the installation manual and wiring diagram to Yousendit.com. Here's the link:
https://www.yousendit.com/download/dVlvdFdVdVVrUmxMWEE9PQ
or
http://tinyurl.com/dhs964
SOURCE: I have a aftermarket alarm that trips 60 sec after armed.
if im not mistaken it does that because your interior lights dont turn off as soon as you close the door.. it delays a lil bit, and when you set your alarm it detects that the door is being opened. try arming your alarm after the lights have turned off and if that solved it you can take your vehicle to an alarm place for them to program your alarm to learn that function..
either that or maybe your door trigger wire is tapped to the wrong wire on the car...
SOURCE: I bought the car with wiper alarm system and
it may need to be programmed.......
-press the "f" button and hols for 12 seconds (ignore the beep at like 4 seconds.)
-press and hold the unlock button for 2 seconds...the remote should beep two times. each feature that is active will have an led light beside it. press the button to activate the feature. if the light is on the feature is on...
hope it helps...
SOURCE: i have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
