Question about Uniden Cordless Phone
Getting 'busy signals and line in use message' on my phone.
I keep getting busy signals on my phone (DE model 27959GE6 - a) and a 'line in use' display .
Checked the lines and they look okay. tried tkong it out for a break and alternately switch to a vtech brand with the same result.
The "line in use" indicates that there is not enough current on your line, either there is a broken wire and the phone is not getting any current, or there is a short on your line reducing the current on your line.
you should unplug your phone and check with a diffrent phone to see if there is any dial tone on the jack that you have a problem with... if everything is good with a diffrent phone then it is likely that the trouble is your phone, if the trouble still exists, bring a corded phone to the NID outside of your home, and test if there is dial tone there, and that you can make and receive calls... if the trouble goes away, they you need to troubleshoot further inside your home, if the trouble still exists, then you have a trouble outside that your local phone company needs to take care of, and you should contact them so that they can make the repairs..
Posted on Feb 09, 2009
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
Panasonic KX-TGA101 not working
By jim_giardine on Jan 03, 2010
My parents have had their Panasonic KX-TGA101 for a little over a year and it just stopped working. It no longer rings when a call comes in. Plus when we try to answer a call or place a call all we get is a busy signal both auditory and in the display window.
SOLUTION: you might want to change a new phone line, that's maybe the culprit, most of the time is the phone line is worn out first due to too many reasons.
Jan 03, 2010 | Panasonic KX-TGA101S Cordless Handset
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Dispalys says line in use
Try another phone. The line may be dead or the wiring to the jack may be bad. If possible test at the box where the line comes into the facility. Also if you have another phone, fax or computer modem, dsiconnect these as one of them may be "off hook" and killing the line.
Aug 09, 2009 | Panasonic Lands Phones
My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Mar 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
I have a panasonic phone model number KX-TG6022B and wheather the phone is on the base or not, it says line in use. The line isn't in use though. I've tried unplugging both phones from the base and wait,...
sounds simple
3 things to look at
lets start with obvious i hope you have manual for phone still cause typen instructions for deregistering phone is long type
the reason phone could be showing its still in use is because phone needs to be deregistered and then reregistered back on the hand set base
the other thing is one of your neighbors has tapped your phone line giving you this busy signal
or say you still using dial up on your comp this will show a busy signal cause its using your phone line to get online
Jun 01, 2008 | Panasonic Lands Phones
Vista Home new computer causing busy signal on home phone
In the modem there are two link one for the phone and other for the line . In the line link you have to connect the direct phone line and phone link you have get the extent cable, link it and connect it to the phone . try it and porb comes inform to
May 12, 2008 | Dell Dimension 3000 PC Desktop
Md 760 series cordless telephone system
Try unplugging all telephone (including the base unit), then try to call the number again. If there is still a busy signal, then the problem is with your telephone line/connection and you need to call your phone provider. On the other hand if the number rings, then chances are that base unit is defective (or one of your other phones physically connected to the tel line.).
To verify that it is the base unit or one of the other wired telephones,  reconnect them one by one and determine which of them will cause the busy signal. Problems like this can be caused by a power surge, near lightning strike or a simple component failure.
If it is the base unit, it is very likely an electronic problem and therefore would require familiarity with components and circuitry diagnosis, soldering and use of a DVM. Perhaps your best bet would be to seek the services of a qualified phone technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Motorola Mobility MD761 Cordless Phone
Uniden Cordless Phone Logo
317 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
