Older roper 9 cycle Heavy Duty Washer (Extra Capacity)
The washer may or may not be old? I will get the exact model # if it is needed.
Washer fills normally then stops on any wash or rinse agitation cycle then overfills and floods. Moving the fill selector makes no difference when this occurs? Thank you in advance for any help.
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
I have a roper heavy duty extra large capacity washer the water comes into the machine fine but runs out just as fast, it won't fill up.
Go direct to the maker. This sounds like the pump is running continuously, or do you mean it empties on the floor?
If the latter, a hose has come adrift or split/perished?
Welcome to Roper Home Appliances
Sep 12, 2015 | Roper Washing Machines
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
I have a hotpoint , heavy duty large capacity washer and it runs but after each cycle , you have to manualy turn the knob to next cycle for it to work ,it is an older washer but does it just need the knob...
Some of the old washers have a delay between each cycle that seems long but less than 2 minutes. If this is not the cause you will need to order a new timer not the knob. Sorry if its very old it may not be worth it.
Aug 16, 2010 | Hotpoint Washing Machines
Kenmore Extra Capacity Heavy Duty Washer, Model 4151090, Ser. No. Ca2301977, unable to find a parts list for this. Agitator won't spin, motor and pump works, it's older but can it be repaired?
I would try http://www.appliancepartspros.com/ I am sure that they can find the parts you need. They are the best place for parts and customer service. You will have to contact them because your model number doesn't come up in the search area, but I'm sure they can help. Ive gotten parts from them for a 35 year old GM Frigidaire washer.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Help with my washer
The lid switch is probably broken does it just sit there at the first spin cycle??? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!
Sep 30, 2007 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
