Question about Acer Aspire 5600 Series 5630-6951 Laptop
Not able 'to use some keys and 'two four six - Acer Aspire 5600 Series 5630-6951 Laptop
  • XCal1bur May 11, 2010
    Hi there.
    Just wondering what else you can tell me about his unit. How long have you had it? Did you recently install any new software before you noticed the issue? This is the kind of information we can use to help you out.
    Just from past experience fixing laptops, my gut tells me it's a damaged keyboard or damaged/loose keyboard cable.
    Brigadier General:
  • 5,158 Answers
You have turned on the number keypad feature of the laptop... try tapping fn and nm once at the same time and see if that fixes it.
Robert
Please take a moment to rate this solution thanks
Posted on Jan 26, 2009
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
Eight multiplied by ten to the power of six divided by four multiplied by 10 to the third power
Press 8 [*10^x] 6 / 4 [*10^x] 3 =
[*10^x] is the key just below the 3 key.
Sep 08, 2011 | Casio fx-300ES Calculator
What is the name of the manual 4 speed transmission for the 1984 dodge d100 with a 3.7 (225ci) motor, and with that trans match up to a 5.2 (318ci) motor?? thank you
The great Dodge slant 6 engine...these were very strong and dependable, i put 300,000 on a 1985 D100 and it was still going strong when i sold it. Your transmission is a "883"
Chrysler began using "833" four speeds in passenger cars in 1964. The transmission was designed by Chrysler and manufactured by New Process Gear Co. Chrysler installed the 833 four speed behind the Slant Six at two different times. The first production four speed slant sixes were the 1964-66 A-body four speed cars. The second run of production four speed slant sixes began in 1975 with the release of the Overdrive A-833. From 1975 until 1987 the Overdrive four speed was installed in slant six applications of A-bodies, F-bodies, and light trucks (D100 & D200 series trucks). These applications were not ultra rare, but the slant six four speed production figures pale in comparison to the number of V8 cars that received A-833 four speeds. Since the A-833s installed behind slant sixes were basically the same transmissions installed in the V8 cars, a slant six owner looking to install an A-833 should be familiar with all the A-833s produced, including the ones used behind V8s...There are several characteristics of the various A-833s that determine which four speeds fit in which chassis and with which engines. For the passenger cars, Chrysler manufactured two different length four speeds. The A/F-bodies received a short tailshaft A-833 and the B/C/E-bodies received a long tailshaft A-833. This difference is obvious when one of each type is sitting side by side, but either type is easily identified when it happens to be a stand alone unit.
If you are looking to replace your truck tranny, you will need to find another one out of a truck that had the slant 6 engine for it to be a direct bolt up. Chrysler made several variations.
1975 thru 1987 Overdrive 3.09:1 - 1.67:1 - 1:1 - 0.73:1 (Trucks used a 0.71:1 fourth)
Good luck, hope this helps.
Jul 11, 2011 | 1984 Dodge D150
Hi, I have forgot the security code for moto ming...
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
type *#06# on your phone to get it.
Hold menu button (above directional keys not in centre of directional keys). many people get confused in the 2 buttons as both act as menu button.
Hold it for 3-4 seconds, u will not see any reaction. But when u try to write code, the slot for four digits change to six digits.
Type 000000(six zero) at that slot. OK !!!!
and u will bypass the security code.
Aug 21, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Number four and six in my toshiba keyboard is not working
Try to clean your key board with smooth brush. if problem remains . Then you have to change key pad
May 03, 2010 | Computers & Internet
I have renault migan,and i need to put in my code to switchon the car radio, what do i do?
say the code is 3456 you hit the number 1 key three times the number 2 key four times the 3 key five times and the number 4 key six tmes. then to store it you hold down the number six.
Dec 28, 2009 | Electric Renault R26 Radio Control Car
How many spark plugs are there?
Depends upon if you have the four cyclinder model or the six cylinder. The four cylinder would have four spark plugs and the six cylinder would have six spark plugs.
Aug 08, 2009 | 2001 Oldsmobile Alero
I forgot my phonelock code and security code. my phone model name-Motorola L7i
just go to the option where it asks for that code.their must be space for four digit code.when u will go their just press the menu button which is their in the centre of the navigation key and u will see the space has increased from four digit code to six digit code.then u out 000000{six zero} in that and then code will be unlocked.u can always change the four digit cide but 000000 code is inpenetrable.if u want to change the code go to change passwords option and do the same software will ask for the desired code which wud be of yr wish.hope it helped u.enjoy
Mar 10, 2009 | Motorola Mobility L7I Cellular Phone
Motorola slvr L7
Hey dude,
have this trick to bypass the security code.
Send a feedback and rate my solution too.
Be sure to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
Jun 04, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola slvr phone, i forgot my four digit password.
Hey dude,
May 10, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Acer Aspire 5600 Series 5630-6951 Laptop Logo
Brian Sullivan
Brian Sullivan
