Question about Viking VISC530-4BSS 30" Electric Induction Self-Clean Freestanding Ran
Burners go on high, no control with switch
When the stove is turned on burners go to high even if switch is in low
My problem is the large burner on this stove tends to do somewhat ok on anything below a medium temperature. If you turn the burner to medium it escalates to high and refuses to lower even when you put the...
Replace the switch that controls this burner to get it back under control. This will solve your problem as the switch is what controls the burner temperature regulation.
Good luck!!
Jun 15, 2010 | GE JBS03 Electric Kitchen Range
Troubleshooting electrical stove
Infinite switch, it's not cycling internal contacts are welded together, make sure control it's set on low, if the heat element. stays red hot, replace control (inf. switch).
Dec 23, 2009 | Kitchen Ranges
I turn my burner on at medium -no problem. When I
If you cannot regulate the temp on any surface element the problem is not in the element but rather the "infinite" switch. You need to replace the switch's if you can't control the hi and low on the burners. The switches will be different for the small burner and the large burner because of the different wattage on the burners.
Nov 11, 2009 | Kenmore Kitchen Ranges
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
2 burners get red hot no low control ??
Change the burner 2 switches. if they dont turn down to low, then its the burner switch.
Nov 17, 2008 | Brown Stove Works EM610 Electric Kitchen...
Burner adjustment
After discussing the problem with your advisor it was determined to be a faulty infinite burner control switch. I purchached a replacement and the stove works fine.This service was very halpful to me.
Jul 21, 2008 | Jenn-Air Kitchen Ranges
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Viking VISC530-4BSS 30" Electric Induction Self-Clean Freestanding Ran Logo
16 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
