Why is there no Signal on the DVI input with my MacBook Pro?
Tried everything... restarted computer, reset TV, unplug/re-plug TV. I'm using a DVI-D Cable with an Apple mini-display to DVI adapter. I've tried clicking "Detect Displays" in Display Settings on Mac. All I get is "No Signal" on the Television.
  • ml74 Jan 22, 2013
    Thanks for everything here... the TV is HD, but it hasn't got any HDMI inputs. Only DVI and VGA. I know the sound will have to run separately to our stereo receiver. I've ordered a new DVI-D cable that is Single Link instead of Dual-Link. And I've ordered VGA Cable and VGA-Mini Display adapter to try connecting that way.
  • ml74 Feb 17, 2013
    My MBP is early 2009, so mini-display port is what I've got. I tried the DVI-D to mini-display and it didn't work. Would VGA to mini-display work, perhaps?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,003 Answers
Is your television DVI-D or DVI-I?
If it cannot see the digital display, that might be the problem.
Posted on Mar 09, 2015
2 Suggested Answers
  • 25 Answers
SOURCE: I'm trying to hook up my Westinghouse L2410NM 24
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
Posted on May 07, 2011
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Television inputs keep telling me that i have no signal or no input when i try to switch over and use my ps3. this is weird because i was using it when this problem occurred, so everything should be...
Try resetting the signal from the PS3.
Press the power button and hold it until you hear a few beeps in a row.
Power it off again, then back on.
Make sure to have the TV set to the input the PS3 is connected to & turned on before starting the PS3.
Peter
Mar 26, 2010 | Samsung (TN-RBNG10) TV Input
Macbook pro VGA color display problem
Go into system preferences, click displays, and make sure your color status is set to millions not thousands.
Nov 17, 2009 | Apple MacBook Pro Laptop Computer with...
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
VG910s not recognizing DVI input
Graphics card need setting to DVI out put Check your manual
May 16, 2007 | ViewSonic VG900 19" Flat Panel LCD Monitor
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
