Question about Kyocera Copystar CS-1635 Copier
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
    Problem Solver:
  • 7 Answers
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Posted on Jan 24, 2013
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
SOURCE: Kyocera Mita KM-C3232- Error Code C6000
The power source board may have created this problem and replacing the fuser may only be a temporary fix and after replacing the power source you may to replace the fuser again.
Posted on May 11, 2010
shawn38
  • 200 Answers
SOURCE: My photocopier has been displaying
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Posted on Mar 08, 2011
SOURCE: j'ai un probleme avec mon
KYOCERA KM 1505 . CODE PANNE C 610 DE
Posted on Mar 13, 2011
SOURCE: My Kyocera Mita KM-KM 1635 displays error call c6000
press 1087 1087 than insert 163 than press start 4 time
Posted on Nov 21, 2011
How to resolve the problem c6000 Photocopier name Kyocera multifunctional km1650
I have provided a troubleshoot guide. Hopefully that will help you.
http://www.scribd.com/mobile/doc/60850340/Kyocera-Service-Error-Codes-Summary
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 04, 2016 | Kyocera Office Equipment & Supplies
My kyocera 1635 copy shows c6000 error i need a code to cancle it
u cannot clear it if it is c600... if is c6400, u can fix it by entering mtce mode: press 1,0,8,7,1,0,8,7 in sequence after switch ON; u get "U" ,, now enter 1, 6, 3... press enter/start; cle appears; press enter/start; u get the machine ready now. if c600 fuser lamp might be blown, needs replace; first try as above.
Apr 04, 2014 | Kyocera Copystar CS-1620 Black and White...
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My Kyocera KM 1635 / 2035 displays error message: error call 600
Needs a service, either call your photocopier service company or find one on google.
Mar 19, 2012 | Kyocera Office Equipment & Supplies
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
Quand j allume le Kyocera 1635 sur l ecran clignote C-6 Puis 000
Bonjour.
Le C6000 erreur est une faute dans la section fuser (lampe unite' de fusion)
Voici les causes:
1. problème d'alimentation ou de tension
2. Le fil a' thermistance deconnecte'
3. Mauvais contact dans les terminaux thermistances connecteur.
4.
Lampe fuser
Debrancher le cordon d'alimentation pendant dix minutes,
s'il vous plait .
Si le C6000 ne disparait pas, appelez le telefone inscrit sur le manuel s'il vous plait.
Jan 27, 2010 | Dryers
Hello
C6000 is the code for a heat unit error. Either a lamp is defective, or a thermal fuse blown or maybe a thermistor (heat sensing device) is dirty or bad.
Jun 24, 2009 | Kyocera Copystar CS-1635 Copier
Kyocera Copystar CS-1635 Copier Logo
178 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
