Put rubbing alcohol in washing machine
What do I do now. The rubbing alcohol (half a bottle) was dilute with a gallon of water in the machine. Then I realized, oh no that's flammable, and got the water, alcohol mixture out of machine (as much as I could, tiny pool left) What are next steps to make sure my machine is safe?
  • Keaton Shyler Jan 20, 2013
    "David Thank you. Follow up question. With the clothes that are soaked in alcohol, should I wash them in the bath a couple times (with detergent) to release those fumes before placing in the machine. Will that be good enough to remove the rubbing alcohol and the danger quotient. Many thanks! "
    President:
  • 2,976 Answers
Run it with a FULL LOAD of water and detergent but NO CLOTHING. It will wash the rest out. If you are near a slop sink, you can just fill it with a hose to dilute any remaining fumes.
Posted on Jan 20, 2013
Testimonial: "David Thank you. Follow up question. With the clothes that are soaked in alcohol, should I wash them in the bath a couple times (with detergent) to release those fumes before placing in the machine. Will that be good enough to remove the rubbing alcohol and the danger quotient. Many thanks! "
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: the washing machine won't drain the water, the
drain screen or hose is most likely clogged. That is usually the case when they don't drain. Newer machines are really tempermental this way.
Posted on Jul 10, 2009
skyblue67
  • 71 Answers
SOURCE: when the wash is finished it doesnt drain the
 Make sure that there is no blockage in the drain hose and that it is not kinked.  Is the drain hose installed correctly?  If you have connected your machine to a sink waste system, make sure that you have cut out the membrane from the under sink drainage system.
 Ensure that the drainage system, standpipe or under sink connection is free from any blockage. - If any of the above are found to be the cause of your problem you will need to run the machine through a spin only programme.  If you have chosen ‘Rinse Hold’, the light will flash until you press the ‘Rinse Hold’ button to continue the programme.
Posted on Jul 19, 2009
How to clean coffee stains on white coffee maker
Plastic can absorb Stains, so you will need to use some kind of bleaching poduct.
some products you can try individually:
  • Baking soda
  • Bleach
  • Water
  • Vinegar
  • Rubbing alcohol
Dilute with luke warm water , except for Rubbing Alcohol
Use some kind of tray which you don't mind if it gets bleach stains to protect your countertop. put the device on the tray.
If you can't soak an item, try disconnecting the device, then wrapping a lightly soaked hand towel or paper towel over the area that is discolored
Rinse with luke warm water, and make sure device has completely dried before reconnecting.
Aug 03, 2016 | Cuisinart DCC Coffee Makers & Espresso...
Can I use iso heet
no reason stated? why not just run fuel, its already ready to run
and in USA< (not stated either) has 10 % ethanol already
iso heet comes in 2 types, ethanol and methanol.
if you buy the ethanol its useless here, like adding 1 drop of peee in the ocean of ethonal
but the methanol , is good for known fuel line icing.
id not mess with it. at all. leave the chemistry to your fuel co.
send 5min and read the MSDS sheets on both and see,
one bottle is blue other red.
i believe (too lazy to look it up for you) ISo means its ethanol.
ISOPROPANOL
99% in your bottle is it is
Isopropanol is the simplest secondary alcohol, also known as isopropyl alcohol or more commonly as rubbing alcohol.
minus the rubbing oil, sure.
your 20 gallon tank (guess) is 2 gallons of ethonal, inside.
so how much water can it suck up,
50 times more that pure gas.
fresh fuel is less than 1% water (in the ethanol part)
and can rise to 4% stored. in 60 days.
longer invites phase change, and the water releases. bad idea.
but you empty one tank per weak so it is a water eating system already, big TIME.
Jan 07, 2015 | 2006 Chrysler PT Cruiser
How many gallons of coolant does the northstar engine hold?
Coolant should be mixed in most cases to a 50% concentration, meaning one gallon of undiluted coolant will provide two gallons of diluted coolant. Most engines will hold 2-3 gallons of coolant mix. I normally purchase two gallons of undiluted coolant. I pour the first gallon of undiluted coolant into the radiator, then fill the empty bottle with water and add that to the radiator as well to make it a 50% mix.. Then, I pour half the second bottle of undiluted coolant into the empty coolant bottle, and then top both off with water to make two gallons of 50% mix. I then add coolant to the radiator as needed until full, keeping the remainder for topping off later as air purges itself form the system.
Sep 04, 2014 | 1997 Cadillac DeVille
What kind of sugar or alcohol is in vodka?
ethyl alcohol is the type of alcohol in vodka (and all alcoholic drinks)
For centuries potatoes provided the sugar to distill vodka but lately some fruits are used in more modern version.
Jul 24, 2014 | LUKSUSOWA Wine & Spirits
Radiator capasity
When I'm doing a radiator I buy two gallons-you then follow instructions on bottle for diluting with water-some come pre-diluted- Denny
Nov 27, 2013 | 1997 Mercury Mountaineer
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
Can i clean plastic fans by rinsing
You have a couple options but an alchohol based cleaner would be your best choice since it will evaporate. Stay clear of anything with added fragrances though. They might leave a residue. They make a product specifically for washing electronic components called Blue Shower. it iis kind of pricey though; http://www.mcmelectronics.com/product/20-2100&t=1 You can usedenatured alchohol. I've used this to clean fans that were not a standard size to get extra use out of video cards and northbirdge fans. You can actually run then submerged in the stuff but it is dangerous. It doesn't conduct eletricity so there's no danger of burning out the fan but it is flammable so I wouldn't recommend it.
Jul 26, 2011 | Dell Optiplex GX280 (99301) Motherboard
Can I dilute Scotts Miracle Grow for use in my Ortho dial spray bottle?
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
Jul 23, 2011 | Garden
I have a 94 oldsmobile cutlass supreme it has a miss but i change plus wires fuel ign,
what you may have are clogged fuel injectors,simple to clear up. add lucas fuel injector cleaner to your fuel tank. suspect bad fuel? water in fuel? 1 bottle of clear rubbing alcohol added to your gas tank should clear up to 1 gallon of water in your fuel tank. the alcohol will not affect your engine at all. it will only dry the water up that may be mixed in your fuel,be prepared for this as gas prices will continue to rise .hope this helps.thank you for choosing fixya.com
Feb 27, 2011 | 1994 Oldsmobile Cutlass Supreme
Washing Machines Logo
965 people viewed this question
Top Washing Machines Experts
