DVD player not working on Logik L24FED12
Have just bought Logik L24FED12 TV with built in DVD player that wont work.
  • 7 Answers
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Posted on Dec 25, 2007
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
  • 8 Answers
SOURCE: dvd stuck in the dvd / tv
I had this same problem and fixed it too. It was from a flat torsion spring on the loading mechanism that had moved position. It hits against the chassis of the DVD housing preventing the mechanism from seating the disk on the spindle. Result is a stuck disk and/or constantly running loading motor.
Remove the one black machine screw behind the DVD player. DVD player will slide out of TV with its black plastic trim fascia from bay.
Remove two screws that hold fascia panel, remove fascia and lift off top metal cover.
With CD loading slot facing you, the problem spring (in our situation) was at the left. Also identical spring on the right side too. These are the two torsion springs near the front on sides of chassis. The helical loop on the left should be towards the top. If it shifted to the bottom, it can hit the tab with screw used to secure DVD chassis. When this happens, CD loading mech can't complete loading disk onto the spindle. If spring flips when the CD is on the spindle.... disk can't eject.
I used a pair of tweezers to gently grab the spring and "flip" it upwards by pulling it upwards. Spring will work for mechanism in up or down position, but needs to be up to avoid interence.
Solved my problem and DVD has been great since. If it flips back for some reason, then I will try attaching a small piece of plastic to the side of the chassis to contain spring in upright position only.
Posted on Feb 24, 2009
  • 86 Answers
SOURCE: 32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released.  My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well.  This will be easier than bringing back the TV for the second time.  If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
Posted on Mar 24, 2009
  • 267 Answers
SOURCE: DVD WON'T EJECT FROM BUILT IN DVD PLAYER.
Try unplugging the set from the wall. wait 20 seconds and try ejecting the dvd. Uint ids going to have to be taken apart if this does not correct your problem.
Posted on Apr 24, 2009
Hiya i bought logik tv/dvd model l24hedw13 soon as i switch it on it goes to scan and keep doing that wont let me to do anything else any tip
what do you have it hooked up to for an input . I use an outdoor antenna and have quite a few channels available here .
Jun 14, 2016 | Televison & Video
Logik L24FED12 HDTV.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 08, 2015 | Televison & Video
Logik tv dvd
It looks like your DVD reader has broken. The fact that it also does not let you eject the DVD sounds like it may be an electrical problem on the unit.
Oct 16, 2013 | Televison & Video
Connecting a dvd player to a logik tv
see the diagram attached: God bless you
Jul 21, 2012 | Televison & Video
Sky+HD remote code for logik L40LCD11
Logik
LK74
726
Logix
LTV3601, RC223
696
Jul 17, 2012 | Televison & Video
I have a UR-3445 and need code for a logik with built in freeview and dvd please
yes it will not work on tv i have so took it back and contacted logik direct to purchase a new remote
Nov 05, 2009 | One For All URC-3445 Remote Control
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
