Honeywell rth111 to a trane weathertron 239 - Heating & Cooling
Master_Tech
  • 770 Answers
SOURCE: need wiring help for replacing
I am not sure of what help you need on it but here are the most common wiring on a stat
W= heat
C=Common (24V)
R=Hot (24V)
G= Fan
RC=Hot (24v for Cooling)
RH= Hot (24v for Heat)
O= Reversing Valve (Heat Pumps Only)
Hope this helps
Posted on May 11, 2008
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
johnsonr1
  • 91 Answers
SOURCE: Need to know wiring diagram for a weathertron
this link has a good diagram of the wiring. It should help you.
http://www.hvacmechanic.com/forums/hvacr/messages/17573.htm
Posted on Nov 05, 2009
  • 415 Answers
SOURCE: Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Posted on Feb 07, 2010
  • 35 Answers
SOURCE: trane weathertron thermosatat
OK. Here is a Trane Weathertron BAYSTAT240 thermostat wiring picture. This heat pump w/ electric (emergency) heaters is running right now. Notice the G terminal has green wire, the R terminal has red wire, the white wire is jumpered from W to X2, etc. The black wire loop you see in the center hole is unconnected.
This unit is adjusted by leveling the base - loosen the screw to the left of "R" and the one to the right of "F". Twist the base clockwise to RAISE the indicator. This makes the mercury in the switch turn ON at a different temperature. Remember to tighten those 2 screws again.
You will have to experiment several times to make the unit read exactly right. If the tech installed the base exactly level, the unit would read right (it says here).
Posted on Jun 10, 2011
I'm replacing a Trane Weathermen Baystat 239 with a Honeywell RTH6350D. Honeywell manual says the black AND the white attach to the AUX together! Diagrams I am seeing does not support that theory. ??
Yes that is correct. White and black go to your aux terminal. Then be sure you are setup for heat pump with back up electric heat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 08, 2017 | Honeywell Heating & Cooling
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
Changing From Trane to Honeywell
Color ---> New stat terminal
Blue--------C
Green------G
Yellow-----Y
Orange----O
Red---------R
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
Feb 06, 2010 | Heating & Cooling
Need wiring for honeywell pro 3000 in trane xe1200
May 16, 2009 | Heating & Cooling
Trane weathertron thermosatat
Mar 20, 2009 | Heating & Cooling
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
Heating & Cooling Logo
116 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
