Question about Fisher and Paykel Dishwashers
Dishdrawer will not drain - Fisher and Paykel Dishwashers
  • Fisher and P... Master
  • 3,247 Answers
Please provide model number and also confirm whether you have cleaned the filter sump the kitchen drain pipes are also clean.
Posted on Feb 25, 2013
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Dishwasher not draining on final rinse
Time life fix-it-yourself book (used Ebay) worth its weight in gold (get the most recent edition) (I have 3 of them, various authors).
Apr 22, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Hi my F &P dishdrawer unit (DD603) won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Fisher and Paykel Dishwashers
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
Jan 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Same problem
Below is the service manual. Use the FU (fill water) function in the diagnostics and then use P2 to drain the water. Open the drawer and watch will testing.
Good Luck
http://www.scribd.com/doc/6462163/DD601V2-Manual
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
