Question about Maytag Neptune Washing Machines
Code d5 Will not start
  • Maytag Master
  • 17,129 Answers
Please reset the door lock and mechanism, check the door switch, click on Door reset
Posted on Jan 21, 2013
2003 acura tl d5 blinking and jerking
D5 blinking is a trans code, problem. A scanner is needed for the OBD plug to get the code. Trans issues very common on this model.
Jun 06, 2014 | 2000 Acura TL
Tansmission is heatitating and D5 light is blinking
when the light blinks for OD (5th) gear it means that a fault exists in the mechanical or electronic control systems of the transmission, you need the system scanned for the fault code(s)
Mar 28, 2014 | 2003 Acura 3.2TL
When i am moving slowly and the gear is D5 the car will not engaged on till i removed it from D5 and shift it to N and put it back to D5 then the gear will now engaged and started moving and i have run a...
The transmissions on the cars are horrible. The torque converter is usually the cause. Call the dealer. Your transmission can seize and stop causing you to crash.
Sep 02, 2013 | Acura MDX Cars & Trucks
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
What does code d5 mean? The machine will stop and stay idle for several minutes and then start again. This happens several times per load, but eventually finishes.
Hi, The reason for d5 error is due to defective door lock switch. You will need to have this damaged mechanism replaced to fix this problem.
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting an E indicator transmission light
E stands for error. Have the vehicle scanned for transmission codes.
Aug 16, 2009 | 2001 Lincoln LS
Need latest telewest code
telepest-01-D2 EA 29 B7 B5 52 E9 AD.key.00-04 4D 6F 7D D5 C9 F7 9B c/wkey0.2A E0 72 B0 9E 07 9B 5D..key01..B5 8E A1 3E 6F D7 BD D2.
notsopurekeys-key0-31 6F CB 3F 2E 45 5A 04..key01.EA B7 BF B2 D5 AA 46 AB
irelandntlkey0-75 92 B1 CC 6F 23 20 F1..key01-F2 46 B1 59 04 61 77 71
irelandchoruskey0-51 0F 32 A7 D9 34 BE 3E.key01.8D A3 88 1B 4E 32 C5 8F..
all above as of 28/11/08..18.00pm
enjoy....for how long...god knows...but we need a new firmwarte fast...
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
