Question about Philips Cameras
What means Mark II at Philips items ?
Some Philips audio products (deck recorders as is N5151 or 3 in 1 music system - as AH971has the surname ''Mark II '' - what means this ?
    Genius:
  • 1,019 Answers
It is a series designation in some item models that means mark II was made after the mark I series, so a mark III unit would be a later model than the others.
Posted on Jan 25, 2013
How Do i Fix My i Tunes Music ~~~~ They All Have An Explanation { ! } Mark On Them..???????????
Are you sure it is not a cloud symbol and arrow? That means they are being played from iCloud and are not downloaded to the device.
In your case however, you have deleted them or moved them.
If you see an exclamation point next to your items in iTunes
How to get rid of exclamation marks in iTunes, and get your music to play
www.macworld.co.uk/.../how-get-rid-of-exclamation-marks-in-itunes-music-play-360...Mar 3, 2015 - How to locate missing iTunes music and fix the exclamation mark problem in iTunes. ... How do I get rid of the exclamation mark and play my iTunes music again? ... Typically you'll find them in Home/Music/iTunes, but you might need to ... should be able to play all the tracks from that iTunes music library.
Tunes Music Have An Exclamation Mark On Them Google Search
Jul 17, 2017 | Audio Players & Recorders
I have a Kenwood KR V6090 tuner amp. Can anyone please tell me if I need a record deck with or without a pre amp fitted.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
Dec 12, 2014 | Kenwood Audio Players & Recorders
I need a user manual for a Philips Dual deck Cd Recorder CDR775, Model No:775/00 Production No:VN10220230826. I bought one without the cable. I need to know also what cables I need to record live sermons
Dig down in this slow-to-load directory for the manual.
http://www.p4c.philips.com/files/c/
What 'cable' allows live recoding? You need a mike, a mike preamp and from there probably any standard audio patch cords might work. It would depend on the other equipment.
Sep 06, 2011 | Philips CDR775 2-Disc CD Recorder
Have not been able to find digital cd's. Are cd audios the same for use on philips 870
Philips CDR 870 is designed to RECORD with ONLY Audio or Music CD-R or CD-RW discs !!
The word(s) Audio Or Music MUST be written somewhere on the Cd disc or Cd Covers.
Computer CD-R and CD-RW discs will NOT Record on this recorder !!
My experience of GOOD Audio/Music discs : Philips,Sony,Traxdata,Verbatum
My experience of BAD Audio/Music discs : ALL unbranded discs, Maxell,TDK
Dec 16, 2010 | Philips CDR870 CD Recorder
Sound divice
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
Aug 13, 2008 | Computers & Internet
My Sony dual tape deck does not record in stereo anymore.
Oxide deposits on heads can restrict audio transfer to tape. You may need to do a deep cleaning of record head. Depending on how much deposits are on heads may need no more than alchohol and Q-tip. Be sure to clean erase head and drive roller. Afterwards, try recording, then use headphones in jack on recorder to check for recording on both channels. If this works, problem is not in rest of equipment set up. If you still need help, email me
Apr 21, 2008 | Sony CASSETTE DECK Single Dual Cassette...
No Audio 10 Error
What have you got hooked up? Another CD, tape outs from an amp or a record deck? No audio is a strange message to get, like you say you're using an audio cdr and that's usually what it means. What about if you press record with *no* source connected? Unit should record 20 seconds of silence then cut off.
Jan 20, 2008 | Philips CDR765 2-Disc CD Recorder
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
Problem with Sony RCD-W1 CD recorder
'No audio' comes up when you use the wrong type of cdr in the drive. You need a 'consumer audio' or 'music' specific CDR and not a generic computer cdr to use in these units.
Sep 27, 2007 | Marantz CDR631 CD Recorder
Cameras Logo
79 people viewed this question
Top Philips Cameras Experts
Are you a Philips Camera Expert? Answer questions, earn points and help others
