Kemore elite oasis top loaders unbalanced - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 21, 2013
SOURCE: unbalanced load cabrio top loader
i am on line now- we checked with a level and its right on... i have been washing on the normal cycle and then using the drain/spin cycle to spin out as much water as i can..that cycle even displays the ul code...its always displayed somewhere between 12 mins left and 7 mins left...i dont know if that has something to do with it??
Posted on Jan 13, 2008
  • 125 Answers
SOURCE: kenmore elite oasis he top loader
Is it an f code followed by a 51?
Posted on Jan 21, 2008
emissionwiz
  • 76132 Answers
SOURCE: I have a Kenmore Elite Oasis HE top loader washer;
this is a fault in the water valve control, "LF" means Long fill (fill time exceeeded), so u will need to have the sears guy out to sort this problem out. are the water valves on the wall turned on all the way?
Posted on Jul 15, 2009
  • 401 Answers
SOURCE: coins are in the drum of the washer how do I
It needs disassembled and requires special tools.
Posted on Jan 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: UL ( unbalanced load ) signal appears, washer will not spin
Re-balance the load, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Why dose my kenmore elit oasis he washer keep geting unbalanced with or with out a load in it
Possiable it has a broken yoke on the inner drum, Mine broke completely off. Lucky it was covered by Sears warrenty. Cost is over$1,000 to repair with out warrenty.This is a common problem with He Washers..
Sep 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore elite oasis washer makes noise and unbalanced
If your washer start going to high speed and it make unbalance and bangin on the frame. there was a stator may need replace....good luck
Nov 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis starting to show "UL" and immediately stopped working. How do I fix this issue?
UL = Unbalanced Load
re-distribute the clothes and re-try.
Aug 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
How to remove casing from kenmore elite top loader screws are in the rear of washer
Here's a link to a video on opening a Whirlpool Cabrio which is the same as the Oasis which is just a Sears branded version of the same washer.
http://s160.photobucket.com/albums/t200/Zenzoidman/Washers/?action=view&current=cabrio-fixitnow.flv
Apr 30, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Top load direct drive will not spinn, but pump
oasis checks are complex if this is what it is, most likely you will have an error code, what is it? If its not an oasis, but a reg top loader, replace the motor/transmission isolation coupler.
Jun 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
