Question about Brother MFC7860DW AllInOne Laser Printer
Factory reset brother mfc 7860dw
How to carry out a factory reset on brother mfc 7860dw has stopped accepting fax's on distictive ring
SOURCE: Factory reset Brother MFC-7320
1. Open cartridge cover
2. Press the button Clear / Back
3. Press start button
4. Print number 11
5. Close cartridge cover
Now, your printer is returned to the factory settings.
Posted on Jul 27, 2010
  • 832 Answers
SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Posted on Jan 10, 2008
  • 226 Answers
SOURCE: Brother MFC 8500 Fax machine error "offline"
ok. right click on my computer,
click on manage,
click usb ports,
delete all files named composite device.
unplug the cable from your printer
restart your computer.
plug it again the cable.
start your printer.
good luck...
Posted on Jan 23, 2008
  • 4041 Answers
SOURCE: Brother MFC 420cn "Cannot Init"
This is the Head Error 41
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Apr 25, 2010
SOURCE: brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Posted on Apr 28, 2010
After replace toner keep geting message JAM INSIDE but there is no jam papper
I have a brother printer too, nine times out of ten you have to make sure everything is closed tight
May 30, 2015 | Brother MFC 7860DW - Multifunction fax /...
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
Says manual feed. Load paper
There is a manual fee slot just above the paper tray. Sounds like the manual feed slot isn't closed all the way. Here's a link to support for your machine: MFC 7860DW Others Brother Solutions Center Note there is a firmware update available.
Jun 19, 2014 | Brother MFC 7860DW - Multifunction fax /...
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
How to turn printer from offline to online
Often times the printer will show being offline if the computer wasn't turned on before the printer. Also, if you have more than one printer be sure the printer you are trying to use is selected in the printer setup page.
Aug 16, 2017 | Brother MFC 7860DW - Multifunction fax /...
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother MFC7860DW AllInOne Laser Printer Logo
4,952 people viewed this question
James Cagle
James Cagle
Jim Keysor
