Question about Garden
Hy does water squirt out around the nozzel
A lot of water squirts out around the nozzel instead of through the oopening in the nozzel.
  • 885 Answers
Inside the nozzel, where the tip locks in, there is a groove for an o-ring. If that o-ring is missing, water will leak around the tip as you describe. Sometimes when the tip isn't fully seated in the nozzel and you pull the trigger, the tip goes flying out. The o-ring will fly out also. Most people find the tip but never see the o-ring. The o-ring is usually carried by any company or store that carries pressure washers.
Posted on Jan 21, 2013
4 Suggested Answers
redbeard00
  • 957 Answers
SOURCE: no pressure from pressure washer
Do you plan on doing the repair yourself. I need more info, when you supply water to the pressure washer, pull the trigger to purge air from pump, and start the machine. Do you see water coming out from the bottom of the pump? Do you hear the pump working or is it quiet. If you hear a cycling pattern or hear the pump trying to push the water out but it isn't, then you may have a blockage inside the trigger or the spray tip. If the pump isnt building pressure then you may have a pump problem. A stuck check valve, cracked plunger, bad seal, or could be air bound.
Posted on May 12, 2009
  • 174 Answers
SOURCE: Karcher K 3.86 electric. Was working fine and
It sounds like you have cracked part inside. Parts availability depends on were you live???
Posted on Sep 20, 2009
  • 92 Answers
SOURCE: When hooked up, (electric+water) unit
Dear Sir,
This is a problem like the ones I explained. I will write again the explanation.
Dear Sir, What happened is that you have a control valve (Spill Valve)..that when pressure is created it will closes down and puts off electricity by hitting a micro switch. This happens if one leaves a lot of soap in the system or more often the machine is stored under pressure. Never store a power washer under pressure!! Now all one has to do is locate the spill valve ...lubricate or change with a new one. Always lubricate with silicon grease. Also never put on a power washer on without water being fed.
The spill valve is usually located where you see 2 wires coming out on the machine inside.
Well just a small reminder.....if you left the machine stored with pressure...most probably you have the spill valve jamed in the closed position, thus cutting electricity off.
Regards, Fulltech
Posted on Apr 20, 2011
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
Water leak in front passenger side water leaks from heater box area and runs underneath front carpet whenever it rains or when car is washed
you possibly have a leaky windshield. Try turning the heater blower on high , close all the windows and doors and get a squirt bottle with a soapy solution and start squirting it around the windshield edge and see if you get any bubbles from where you squirted the soapy solution. if you do WAH LAH you found where the water is coming in from.
May 02, 2011 | 1993 Mercury Grand Marquis
Cant unscrew Filter...
Hi from retired Englishman in SW France @ 17:58 Wed evening.
Had the same problem with our Bosch- we live in a 'hard' water (lots of calcium) area and I had forgotten to give it a few extra decalcs over the year! I presume your water supply is similar.
I squirted anticalc fluid around the filter cover first but I then put 2 sachets of anticalc powder in the drum together with a large kettle -full of boiling water and left it overnight. It would certainly help clean the heating element at the same time, which is not a bad thing! I then ran a spin- to flush the fluid through the filter.
I then spent- probably an hour- gently but firmly turning the cover back and forward a fraction of an inch each way until it finally undid. This was only half of the story. Normally our filter attaches itself to the cover by a rubber ring but this time it became detached. So- lots of squirts and again lots of patience and eventually persuaded it to come out- FULL OF CALC!!
Best of luck!
John C
Feb 02, 2011 | Hotpoint Washing Machines
The washer fluid in my 03 Honda element wont squirt how do if fix it
Investigation is the only way to find out what is happening, suspect items are pick up screen, discharge nozzels and pump. a quick test is to pull the hoses from the squirt nozzles, and see if fluid will pump. Frozen fluid will not pump.
Jan 28, 2011 | 2003 Honda Element
AWW - the wiper fluid doesn't squirt out onto the windshield, it just sort of leaks onto the hood :((
are both nozzels doing this? if so open the hood, find the hose that goes to the nozzels and disconnect before the nozzels. if it squirts out good there then mabey the nozzels are clogged. to unclogg try breaking a hair off of a wire brush and using it to rod out the orafice in the nozzel
Nov 03, 2010 | 1997 Toyota Tercel
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Water squirts from the top instead of through the coffee
The underseal / group gasket is damaged and needs to be replaced.
Jul 23, 2009 | Breville Die Cast 800ESXL Espresso Machine
1996 Mitsubishi 3000GT windshield washer will not squirt water!?
Recommend remove nozzel and clean,also recommend remove resivior pump and clean screen,may have solvent jelling up.Very comon when using cheaper solvent.note always use an alchohol base solvent in resivior and make sure water jug is clean.
Jun 16, 2009 | 1996 Mitsubishi 3000GT
RE: Frigidaire Refrig/Freezer
try hot water and a turkey baster (or similar squirt device, I got mine at an auto parts store). squirt water into drain. a little messy but a towel or small wet vac should clean it up just fine.
Jun 12, 2008 | GE PTS22SCRBS Top Freezer Refrigerator...
Open Questions:
Garden Logo
386 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
