Question about Garden
2005 polaris fusion 900 idles then dies as soon as you touch the throttle
5 Suggested Answers
  • 93 Answers
SOURCE: Polaris Sportsman 90 - stalls
Is the choke in the on position? Have you warmed it up enough?
Posted on Sep 11, 2009
  • 38 Answers
SOURCE: I have a 2006 Polaris 800 sportsman and it won't stay idleing
adjust the idle screw
Posted on Oct 01, 2009
  • 123 Answers
SOURCE: why does my polaris mv700 quad start, but as soon
Sounds like the ETC switch on the right handle bar is not adjusted correctly. If there is too much play in the throttle cable, points inside the switch will contact and kill the spark. On the throttle cable coming out of the box on the handlebar, there is a rubber boot. Inside the boot is an adjustment screw, turning clockwise will loosen throttle play, counterclockwise will tighten throttle play. The thumb throttle should have 1/8 to 1/16 inch freeplay before it starts to tighten against the throttle cable. Try that and let me know, that usually is the culprit. Daniel
Posted on Oct 10, 2011
SOURCE: 2001 polaris scrambler 90 will
I dont have a solution but mine is doing the same as the posted ones--runs at idle but bogs down with fast fuel feed!! does anyone know the solution?
Posted on Apr 01, 2012
Polaris 4wd 6x6 magnum. Just replaced the carb with a factory new one. Starts fine , but dies as soon as I touch the throttle.
What was wrong with the old carburetor?? I have been working on motorcycles and ATV's for 40+ years... only replaced 5 carburetors..they were broken/damaged by the owner trying to "fix them" or corrosion damage from leaving gas in them for years...
It still sounds like you have a fuel delivery issue...check all your hoses..
get one of these... it will serve you well ...
Polaris atv manuals
Polaris ATV repair manuals
Sep 17, 2017 | ATVs
Headlights work fine. Why are all gauges/ electronic dash out?
Electrical issue - no headlights, tach, etc - HCS Snowmobile Forums
www.hardcoresledder.com > ... > REV Chassis
Feb 2, 2009 - 12 posts - ‎2 authors
There is no voltage at the harness with the relay at all. ... Previous Sled(s): 09 f1k SP,07 f8 SP,fusion 600@900 ... We havea 2006 600sdi and everything works but the headlights. ... relay is good, But this just happend to me sled starts and runs fine ... As soon as I rev it up the dash, tach, headlamp go out.Missing: 600headlights ‎electronic
06 fusion 600 bad volt regulater [Archive] - JohnDee.com ...
www.johndee.com > ... > Discussion Board > Tech Talk
John Dee
79 posts - ‎8 authors
I believe I have a bad voltage regulator going out on my sled. lights are diming and ...I'm under the impression that polaris has replace the old regulator with a new ... They are way down under the oil tank, brake, and all that stuff, up tight ... While riding, my sled had dim lights, no hand warmers, gauges would go in and out.Missing: 600headlights ‎electronic
Polaris Fusion 600 HO LED tail lights - YouTube
? 0:31
https://www.youtube.com/watch?v=oG2BWF4xVKg
Sep 28, 2011 - Uploaded by Trent Robinson
Most Fusion 600 HO owners at some point have issues with their ... This makes sense but the electrical system is AC on this sled AND people complain of the brake indicator on the dash stays onall of the time. ... Not sure on the indicator, mine works fine. ...2006 Polaris Fusion 900 that we are parting out.Missing: 600headlights ‎gauges ‎electronic
battery light blinking with full battery - TrackShare.com
www.trackshare.com/forum/showthread.php?t=32645
Jan 01, 2016 | Polaris 2006 Fusion 600 HO
2015 Polaris 900 won't start. Was starting with fast idle, rough running with backfires, now won't start at all. Was running perfect.
fast idle start usually indicates an air leak somewhere.check carburettor bolts are tight and engine head bolts are tight.try that first
Feb 19, 2015 | Polaris 2015 Ranger XP 900
I have a 98 polaris 425 magnum it idles good but as soon as i give it throttle it wants to die. is this an electrical problem or a fuel problem
turn idle/lean down a bit and see what happens, then the gas may have water,timing, carb could be a few things
Aug 11, 2014 | ATVs
2006 500ho sportsman runs great but it wont idle if you let off throttle it cuts off?
It's the etc remove cap on throttle there is a contact in there should be open ifit touches when you let off throttle will not idle there is an adjustment on throttle cable a few inches from throttle peel back rubber covering and adjust till contact is open that should fix it
Mar 21, 2010 | Polaris ATV
Short?
Check throttle switch , emergency shut off and associated wirring
Jan 18, 2009 | 2005 Ford Fusion
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
