Question about Dishwashers
Hi,I have a Kenwood KDW45X10 dishwasher that's
  • Lee walker Mar 17, 2013
    Hi,I've checked the heater resistance and is 29 Ohms so think is ok.There is a swicth connected to the pipe that comes from the heater with two wires going to it-is this the control switch? how do i test it?Should i power the unit up and bridge these terminals and see if the heater comes on?
  • 236 Answers
SOURCE: Siemens Dishwasher SE26230GB
the element will be housed in a plastic manifold that is located at the centre rear of the d/w base. you may have a resetable thermostat on the top so give it a try first.
Posted on Jun 11, 2007
SOURCE: Zanussi DE540X Dishwasher
I have the same problem. First fault was caused by poor workmanship on the assembly of the PCB. There is a relay (the largest component on the board) which was badly soldered and caused some arcing resulting in solder splattered around the plastic casing and a lost electrical connection. This relay switches the mains voltage on to the heater i.e. 240V around 8.5A for a 2kW heater. (26 ohms suggests a 2215W heater for the case mentioned). Re-soldering this connection solved the problem for about a year. Now the dishwasher is showing the same problem. I have tested the relay and it is operational, but does not seem to be turning on during a wash cycle. A new board costs around £100. Zanussi will not even provide the technical details to allow a home fix. I will post my finding if I get to the bottom of this problem. It may be to do with electrical temperature sensor. My hunch is the controlling PCB is cheaply made and will not last a reasonable lifetime. A dishwasher is in itself a very simple piece of equipment with only a few valves, a pump and a heater so should not give problems in its first five years of life subject to normal usage. I will not consider purchasing any Zanussi appliances in the future.
Posted on Jun 20, 2007
  • 236 Answers
SOURCE: Zanussi DW907 Dishwasher stops early in cycle
the heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
Posted on Feb 16, 2008
gary1121
  • 332 Answers
SOURCE: IDL40 only washes in cold water now.
YES IT SOUNDS LIKE IT'S THE ELEMENT OR MAYBE A WIRE HAS COME OFF THE ELEMENT FROM VIBRATION,
Posted on May 29, 2009
SOURCE: no hot water
A dishwasher only has one supply line: hot water.
The problem with this washer is most likely either the thermostat which controls the heating element or the heating element (or connections to it).
Hi there I am trying to look online (without success) to find a manual for a Kenwood Slimline Dishwasher KDW45X10 does anyone have this? Many Thanks
It is here
https://www.buyspares.co.uk/images/mediator/90/1%29%20instruction%20manual%20kdw45x10_ib_final110323.pdf
Jan 02, 2015 | Kenwood Car Audio & Video
Bf72 not doing the wash cycle correctly
If you are using hot water connection then check the temperature of incoming water is hot enough. If cold water inlet only is used then most likely the heater element or thermostat in the dishwasher is faulty and the water is not heating enough.
Nov 04, 2012 | Hotpoint 24 in. BF72 Built-in Dishwasher
Kenwood dishwasher kdw12ss stuck in cycle
Sure the name isn't Kenmore? If it is try a new control board GE affiliated washers have been getting some problems with them. I can get you the part number if you post the model no located on the door jamb of your machine.
Aug 06, 2012 | Kenwood Dishwashers
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Unable to reset wash program
Press and hold the start/stop button for a few seconds.
Nov 25, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
