Question about Epson Stylus Office Equipment & Supplies
How to reset code for Espson C120 Stylus
Both lights are flashing and need help to reset them
  • Epson Master
  • 511 Answers
Flashing alternately can be fixed by using resetter/ adjusment program.
But flashing simultaneously can't be. It's fatal/general error, error that can't be resolved by printer itself.
Posted on Jan 21, 2013
  • Shelly Jan 21, 2013
    Anajazmoro can you send me the link for the resetter/adjustment program? I downloaded one that reset counters and it didn't help.
  • Anjazmoro Wicaksono
    Anjazmoro Wicaksono Jan 22, 2013
    How about Epson Status Monitor. General Error or Service Required?
Cx7800,epson
All lights flashing isn't something you can "reset". Are the lights flashing alternately, or together? These are different errors.
Alternating means that the printer thinks the "waste ink pads" are filled and need to be replaced (costs more than a new printer). You can reset the counter, but then you run some risk that the waste ink will overflow your printer onto the surface where it sits. messy.
The SSC utility will help you reset it if that's what you want.
SSC Service Utility for Epson Stylus Printer
Apr 13, 2015 | Epson Office Equipment & Supplies
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Cheers
Apr 05, 2011 | Washing Machines
How to turn change oil light
iI you mean 'how to turn change oil light off" go to fuse panel. Open drivers door there is a panel cover on the side of dash board, remove cover there is a red RESET button that resets oil pressure and tire pressure. Turn the ignition key to the on position but don't start the car. Now press and release the reset button the change oil light should start to flash, now press and hold the reset button until you hear chimming hold until chimming stops then release, the change oil light should go off. If you need to reset tire pressure press reset button twice, the first push will make the change oil light flash the second press will make the tire pressure light flash then hold untill chimming stops, light should go out . Hope this helps.
Sep 30, 2010 | 2000 Pontiac Grand Am GT
Reset service engine light
Turn the ignition on and press the trip/oil reset for 12 seconds.The oil change light will start to flash.When the light stops flashing the set is done.Turn ignition off.Hope this helps.Good luck.
Jul 07, 2010 | 2001 Chevrolet Camaro
Clean button will just flash need to know how to reset
The clean light is flashing due to a failure in heating the water properly. Follow the link below for instructions on resetting the control and information on what may have caused the failure. Let me know if it was helpful.
Clean light flashing
May 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My DI-524 router flashing power light and flashing 4 light
try doing a factory reset on the router - you will need to know all the settings in the router as these will be needed to be re-entered button or hole on the back labelled reset , hold the button - or using a untwisted paperclip in the hole - for 10secs The router will now be reset
Mar 07, 2010 | D-Link AirPlus DI-524 Wireless Router
Power and internet lights flash slowly green & if i press reset button then power light flashes green to red. No other lights illuminate.
Try a hardware reset by holding in the reset button on the back panel (need a pin) for 20 seconds as you turn it on. If it does not work or you will not get connection from your router to cmputer it means the router has gone bad and need a replacement Let me know if this will help
Nov 27, 2009 | NetGear DG834G Router
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Sb800 will not flash
To reset the device, hold down the "MODE" and "ON/OFF" buttons at the same time for about 3 seconds.
Hopefully that will do the trick. if not you cant contact me for further help!
Jan 15, 2008 | Nikon Speedlight SB-800 TTL Flash
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
