Can't get the washer to start - Washing Machines
One quick thought is make sure the door is closed all the way. On front loaders, the door will usually need to lock before the start button will active.
Posted on Jan 20, 2013
My washing machine wont start,its opening and turning on, all the lights are on but it wont run. Can you help me please
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
A broken washer means disaster in most homes which is why we've created this repair guide to help you fix a washer that won't start. While a washing machine ...
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't fill, start or run ... Front Load Washer Won't Drain or Spin Video: Washing Machine Tips from Sears ...
Troubleshooting a Washing Machine That Won't Start ...
www.doityourself.com/.../troubleshooting-a-washing-machine-that-wont...
If your washing machine won't start, begin by looking at the power source. ... mywashing has filled with water,now it wont agitate,it's like it is dead,could this be ...
Jan 14, 2016 | Washing Machines
Outlet has power,circuit breaker is good. Has power to machine, able to see light on circuit board inside machine.
? 2:00
What to do when your washer won't fill, start or run .... In case awashing machine does not start and is ..
Oct 31, 2015 | Washing Machines
AEG Lavamat Turbo 12710 update. Machine is AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts t
test the following steps and fix it. God bless you
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start the line fuse might have blown.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jan 23, 2013 | AEG Lavamat 12710 Front Load Washer /...
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Started washer, heard 'pop', water started coming out of bottom
Thats not good. Sounds like the seal blew out. Inside the unit there are seals that seal up the parts where they are bolted together. Also there is the pressure connection that could have blown out as well. To determine which is the problem you will need to dissassemble it.
Jun 22, 2010 | Karcher K 593 M Electric Pressure Washer
Power washer will not start
Clean the carb. Change the plug. Get some start fluid but use sparingly. Run the water (pull the washer trigger) while you are trying to start the engine.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Washer won't start a cycle
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off, for the mech to become free.
May 11, 2008 | Kenmore Energy Star 44092 Front Load...
Washer Start/Pause button is Falshing and won't start
Try some WD40 on the door lock. The washer won't start if the door doesn't lock.
Jan 13, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
