Question about Health & Beauty
Manual for model FR-100 foot massager
UV E34209m 73 watts 120 volts 60HZ Listed massager 505J
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: my mde7600ayw is a 3 wire 120/240 v 60hz 5600w.
Hi, yes that is the correct cord all right. If you'll notice the new cord has 2 hot (red & black) a neutral (white) and ground/earth (green) wires. In case you are not sure how to connect I've attached a photo which shows the correct way. If my attachment didn't work, check out you-tube and type in "4 wire dryer hook up". Thanks for visiting "fixya" and good luck macmarkus :) IMG_3336.JPG
Posted on Apr 19, 2010
  • 1388 Answers
SOURCE: A Yamaha EF2000iS 2000 Watt
You can safely use any ul approved device using 120v 50 ~ 60 hz if you stay within the limits of it's potential (in your case 2000 watt). You will probably have a loss of efficiency using a step up transformer and will be very limited on the wattage available at the 220v. Most converters are not designed for continuous use and recommend that you buy a converter with at least 25 % more capacity than you will use. Also to get longer life out of your generator, you should use only 75 percent of its capacity for continuous use. A 2000 watt converter will work fine for loads of about 1500 watts or less.
Posted on Jun 18, 2011
SOURCE: the generator produce onely 73
Check all wiring and fuses associated with you voltage regulator if they check ok, find a way to adjust your voltage regulator replace it. Make sure the unit is running at 3600 rpm as well and making 60 hz.
Posted on Jul 10, 2011
  • 5160 Answers
SOURCE: sewing Machine Manual Singer modle 6215C
Singer has the manual for the 6215 sewing machines on their site for sale or download. The direct link for the downloadable version is http://www.singerco.com/uploads/download/1316_6215.pdf . (Note: Singer does not use the letter suffix in their manuals; one manual will apply to the entire set of machines.)
I hope this helps.
Posted on Nov 05, 2011
Looking for Biodex stationary bike model 950-120 parts
Ask Biodex, since this is a specialist medical product. They should be able to guide you to a spares supplier.
Alternatively try to figure out who manufactures the product, it will be subcontracted
http://www.biodex.com/support
Jun 26, 2014 | Biodex Semi Recumbent Cycle Physical...
I think my iguana has a broken arm. There is no reptile vet's in my area. I didn't know what to do
What part of the arm...most limbs heal by themselves and although the iguana may be slightly deformed for life they do fine ...as long as the proper diet and lighting is provided.
LIGHTING: You must provide a UVB specific lamp so the iguana can process the calcium in the diet to make bones strong.....no UVB lamp = weak and broken bones and deformities. Thats why they bask in the sun ...to get the UVB rays and process the calcium. Look up the disease called Metabolic Bone disease in reptile (MBD)
Go to the Green Iguana society to learn so much more ...care ...diet ... lighting.
Go to Mega Ray (Reptile UV) and order a proper lamp....100 watt SB (self ballast ) 120 volt or get a ZOO MED POWERSUN 100 watt -160 watt.
If your iguana already has signs of MBD they can be reversed with the proper diet and lighting. Don't become another statistic...research info about the proper care......and try to arrange some out door time in the sun ...early morning or late afternoon....20 minutes in the sun is equal to about 8 hrs under a man made lamp, so I have been told.
Good luck
Tips for New Iguana Owners
Welcome To ReptileUV Mega Ray UVB lamps for reptile lighting worldwide
Mega Ray 100 Watt Self Ballasted Flood UVB Lamp 100 46 95 ReptileUV...
Zoo Med Zoo Med PowerSun UV Mercury Vapor UVB Lamp Reptile Mercury Vapor
May 26, 2014 | Reptile
AC surge current?
you are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
Aug 31, 2017 | Fixya.com Heating & Cooling
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
A Yamaha EF2000iS 2000 Watt 120 volt 60Hz from USA - can it be used with Step Up/Step Down Transformer 120 Volt/240 Volt in Australia and what are the complications? Thanks Robert
Jun 18, 2011 | Yamaha Electrical Supplies
What is the wattage on the sharp microwave model r-2a48?
http://www.sharpusa.com doesn't have your manual. But you can find it yourself on the
back of the unit - the wattage should be listed.
If only the amperage is given (you know the voltage is 120 VAC RMS), so using Ohm's Law, you can calculate wattage:
Watts = 120 Volts X Amps
May 13, 2011 | Sharp R-2A48 Microwave Oven
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
Need to convert 120V AC/DC current to 120V AC 60Hz 15W
there is no such thing as "ac/dc" current-its either one or the other--if its a 120 Volts then chances are it is AC already-at 60hz---the 15 Watts or any Watts is the amount of draw from the unit-not the power supplied to it- Watts= Volts(supplied)/Amps(being used) if you only want to supply 15 watts then reduce the amps (with a fuse) to .125amps
Mar 26, 2010 | Computers & Internet
Honeywell HZ514 Baseboard space heater
The power draw would be the same as 15 100 watt light bulbs all on at the same time! If this is on a circuit with anything else (ex; vending machine with cooler. )drawing over 7.5 amps it will trip the circuit breaker! does'nt matter if comercial or home! 120 volt receptacle would be on 20 amp breaker. And as for last question... I know there is a thermostat on front, so as long as thats set right, there should be no reason to fear a fire, if in safe location! John
Jan 28, 2009 | Honeywell HZ514 Baseboard Heater
Health & Beauty Logo
54 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
