Question about Sony PlayStation 2 (PS2) Console
Won't read disc in hard drive
My ps2 won't read the disc in the hard drive. It says on screen that there is a disc in the drive but every time I click on it, it kicks my back to the main screen that displays my memory card and the disc. Do you think I need to get the drive cleaned? thanks
    Problem Solver:
  • 6 Answers
Yes you do need to get the drive cleaned you can get a laser disk that cleans it from either game or playstation or maybe online they usually work
Posted on Jul 17, 2007
SOURCE:
Fix my ps2
push it back first. maybe it'll help.
Jul 09, 2013 | Video Game Consoles & Games
My dell inspiron 545S won't load. gives me error #25
It' most likely that your hard disk drive is defective. Try to boot from a CD\DVD disc, if it does, you have a problem with your hard drive.
Feb 15, 2013 | Dell Inspiron 545 (884116037743) PC...
Ps2 Disc won't respond to a Ps3 when inserted.
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
Oct 07, 2012 | Sony PlayStation 2 (PS2) Console
My ps2 is makeing a werd sound when reading dice
It's not able read the disc - try cleaning the disc, try another disc, etc to narrow down the problem. If it won't play any discs either the lens is dirty or an actual hardware failure in the unit.
Jul 23, 2012 | Sony PlayStation 2 (PS2) Console
My sony PlayStation 2 won't turn on
I believe your PS2 has a short circuit and needs another motherboard. If you can do this yourself, that's great. You can find Motherboards or a PS2 like yours that will not read discs or has Disc Read Errors but will boot up for about $25 on Ebay. If you're not comfortable with Changing out your motherboard, then click on the "Repair directory" at the bottom of this screen. On the Repair Directory Screen, select Video Game Consoles. Choose a good Repair shop.
Aug 15, 2011 | Sony PlayStation 2 (PS2) Console
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  1. Turn on your PS2 without inserting any disc.
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
