Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
White flare top left of screen sony bravia ldl-52W3000.
This has been going on for over a year. Tollerated as it would correct itself after 15 minutes of warming up. Now it doesn't go away. White flare starts about 6 inches wide and narrows at it goes down the screen. Does not enter into the bottom 1/4 of the screen. The TV is 5 years old. Thoughts? Thanks
    Top Expert:
  • Sony Master
  • 74,666 Answers
The capacitors at the main power supply regulator board should be checked and replaced. If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Posted on Jan 21, 2013
4 Suggested Answers
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
Posted on Jul 23, 2009
tvservice306
  • 458 Answers
SOURCE: lines across tv
try cleaning T-CON Board to Lcd panel cable
Posted on Aug 19, 2009
jdvillanueva
  • 2098 Answers
SOURCE: I bought my Sony Bravia KDL-52W3000 LCD TV in the
This kind of symptoms is an indication of faulty electrolytic capacitor. In the first stage of the symptoms, warm-up will make itself stable and it will work fine but it will get worst like what you've encountered right now.
Most of faulty electrolytic capacitor has a physical indication of fault like bulged/dome at the top(see sample picture below) and can be easily identify through visual inspection. Open the back cover of your unit and check the capacitor in the power supply board, once found replace it with same capacitance and working voltage that is printed on its body itself.
If you can't find faulty capacitor with bulged/dome at the top, you may replaced all electrolytic capacitor in the output of the power supply board, it will not cost you much because this is one of the cheapest part on that board, cost only $4 at the most each...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Sep 18, 2011
Sony bravia kdl 52w3000 picture adjustment. The picture is too bug for the screen. I cant figure out how to shrink it.
I have a different Sony, but I think they all work the same. Go to menus (Press Home) Then select "Settings" and select "Screen Settings". Set Wide Mode to "full", Auto Wide to "off" , Auto Display Area to "off", Display Area to "normal". I hope this works for you
Sep 16, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a sony 52 inch bravia kdl-3000 and there is a line on the left side from top to bottom. if its the panel that needs to be replaced what would it cost.
Sony panels run around $1,500.00 and up. Go to Face Book and type in (I Have a Defective SONY TV.) Click on LIke So you can Post Your Problem. Their you can get a replacement TV From SONY !!!! If it turns out that you do have a Bad Display Panel.
Oct 18, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Lines across tv
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Picture problem
This is not a solution but a correction . I stated that there was vertical lines but that should be horizontal Lines. I am having a tech come tomorrow to look at it as it is still under waranty.
Thanks
Jan 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
