Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Replace carriage belt - HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
How can I replace the belt for the ink carriage
Here is an HP Support Forum where a user has posted a detailed procedure for the belt replacement.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=846691
The Service Manual is needed. It's available at:
http://www.hylink.com/PrinterManual.html
Designjet 430, 450, 455C - Service Manual
DesignJet 430, 450C, 455CA - Quick Reference Service Manual
As mentioned, it's a delicate and time consuming operation. I replaced my belt two years ago with little problem. (Be sure to clean the old degraded belt gunk off the drive pully too!)
It's not a job for "Beginners". More like "Intermediate" or "Advanced".
Good Luck!
This is the part I ordered. It was $15
WARNING: THIS IS FOR THE "E-SIZE" MACHINE.
If you have the smaller one, you must research the part number for that.
Carriage belt (E-size) - Long/wide belt attached to the carriage 15.00 0.00 15.00 1 15.00
Oct 21, 2009 | HP DesignJet 450c InkJet Printer
There's an error appears. It was error number 86
86.01 can be a couple of issues pertaining to the movement of the carriage assembly.
1. Too much friction in the Slider Rod. Lubricate the slider rod.
2. The Carriage is bumping into the Service Station. If the carriage
Service Station/Aerosol Fan Assembly.
3. Check the carriage belt for wear. Check the carriage path for debris. If the belt is worn, replace the belt. Also, clean the teeth on the carriage drive motor, the debris from the belt will accumulate on the teeth.
Sep 28, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
Carriage drive belt
hi pls check ur belt teeths. its getting damaged better u will replace new belt.
Sep 19, 2008 | HP PhotoSmart 1115 InkJet Printer
HP Design Jet 3500 cp Replacement of Carriage belt
very carefully, if you can find a belt replacement. i would be surprized if you can find the part. this printer has been out of production for quite some time. remove the left cover, remove the right cover, (you need torx drivers #'s 8,9,10,15,20,25) on the left side, remove the encoder strip, lock the belt tensioner, remove the screws to remove the belt tensioner, remove the carriage assembly, don't forget to remove the trailing cables, make sure you replace the belt exactly the way it came off the carriage assembly and reverse the process to put it all back together. if you can find a certified repair person who can find the parts and has the tools, that might be the way to go. this repair should cost $300-400. if the repair person knows what they are doing. hope this helps.
Jun 03, 2008 | HP DesignJet 3500cp InkJet Printer
CANON IMAGE PRO W6400
This error code is a Carriage motor error. Below is the outline for what to check and what to repair/replace. Good luck.
Cause
This is displayed when a jam or other physical problem puts an excessive load on the carriage motor so that the carriage could not operate.
This is displayed when the carriage motor could not reach the prescribed speed within the prescribed time.
Probable problem locations
Foreign object in carriage movement path, carriage rail, carriage belt, linear scale, linear encoder, carriage motor, engine controller, system controller
Remedy
1. Carriage movement path check
Remove any foreign objects (jammed sheet) in the carriage movement path.
2. Carriage rail
Use rail cleaner to clean the carriage rails if a visual check reveals that they are dirty.
3. Carriage belt
If a visual check reveals slack in the carriage belt, remount the belt.
4. Replace the linear scale.
5. Replace the linear encoder.
6. Replace the carriage motor.
7. Cable connection check
Replace the cable between the carriage motor and engine controller if the connection is not functioning normally.
8. Replace the engine controller.
9. Replace the system controller.
Feb 12, 2008 | Office Equipment & Supplies
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
