Question about Intuit QuickBooks: Pro 2005 for PC
Cant access info tool bar grayed out
After entering my password on the Quickbooks login screen, my company name and Quickbooks 2005 shows at the top but is sort of grayed out and absolutely nothing can be accessed. I am not even able to minimize or exit. The only way to close it is through my windows task manager which says the program is running and that it is waiting for a response from me.
Suggestions?
  • Koenraad De Roo
    Koenraad De Roo Mar 27, 2009
    I have seen this only once before. Quickbooks has the nasty habit of displaying ads for their newer versions in a new window on your computer when starting quickbooks. I was able to work around this once by logging in to quickbooks with a different user, maximizing the window, logging off, logging back on with my own account and the second window popped up visible this time. There was a little checkbox which said "do not show this window again", so I checked it. Never had this problem again.
    I don't know if the issue you are dealing with is the same, so I will post this as a "similar problem" instead of a solution.
    Thanks!
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Is this happening at your workplace and do you have an IT guy that works there. Or is this happening at home? The reason I ask is that it sounds like somehow you lost permissions to open that program
I saw this same problem on a client's computer. BelgianAlien's analysis was correct... problem was an advertisement. Thing was, we couldn't *see* the advertisement because the window wasn't maximixed. Note that you only get those ads *after* you log into your company file though! Aha! So, what I did was click cancel when it would request the password for the company file. Without that, it can't log into the company file (and pop up the ad) and then QB prompts you for where to find the company file. You can maximize the window now, log in, kill the advertisement, and go about your business.
Posted on May 10, 2009
HOW TO CHANGE PASSWORD
Access your router by entering your IP address into the IP address tool bar at the top of the page. The linksys address is 192.168.1.1.You will be prompted to enter the user name & password. Enter admin for user name and admin for the password. It will probably update firmware automatically and you will now have unrestricted access to the system's utility software including change of password.
Jun 27, 2015 | Linksys RV082 10/100 8-Port VPN Router...
Locked out of macbook air 2010 forgot username
Boot holding down the Option Key, Select Recovery Mode, when you select languish, click Windows on the top menu bar and select Terminal. Once Terminal opens, type resetpassword. You will then see a pop up window. Select Hard Drive, select USER that pops up in login screen, change the password, click save, then restart. Once your in the login screen, type the new password and your in. For all other locks (EFI / iCloud) go to www.iunlockefi.com
Jan 03, 2015 | Apple MacBook Mac Notebook
Quickbooks error code 6000 80
The error -6000, -80 typically occurs when you are using your company file over a network and its data is either converted or restored. To resolve this error you may use "QuickBooks Company File Diagnostic Tool". In a case if you still have issue with accessing your QuickBooks file then you can try a third party QuickBooks Recovery tool to repair your corrupt file. QuickBooks repair software
Sep 19, 2013 | Office Equipment & Supplies
Cannot receive new password on 2009 Quickbooks
Intuit has an automated recovery tool to remove passwords. search the QuickBooks support site for Password Removal
Nov 07, 2012 | Intuit QuickBooks Pro 2009
Cant open quickbooks , message pops up error code 8000ffff
If your problem did not solve till now, i would suggest you third party tool which will repair your corrupt QuickBooks file and save your data in working condition.
http://www.recoverfilesdata.com/quickbooks-file-recovery.html
Free to Try Version is Available
Aug 10, 2012 | Intuit QuickBooks Pro 2008: Windows
Forgotten password for quickbooks
http://support.quickbooks.intuit.com/support/passwordremoval.aspx
Sep 26, 2011 | Intuit QuickBooks® Point of Sale: Pro...
Cannot access the program, it is passworded (But I never set one)
There can be a couple of causes for this:
1. You are trying to open a different company file than you typically work in ( search the system for *.qbw, there may be file located in different folders)
2. A portion of the database may have become damaged.
If the database is damaged, you would need to have data recovery run on it to fix it. The problem is that you are using v 2003, which Intuit no longer supports. They only way they may fix it is if you are updating to a newer version, such as 2009.
One other thing you could try is to make a copy of the file, and see if intuits free password removal tools can reset the password.
Feb 05, 2009 | Intuit QuickBooks Pro 2008: Windows
I have a company in Quickbooks Pro 2005 that I cannot reopen. The password won't work. I'm the administrator and the password that I usually use simply doesn't do it. I need to reset this company password...
Good morning, my name is Karin.
To solve this, first be sure that you don't have the Cap lock on and retry the ID and password.
If that isn't the problem and you still can't open the file, QuickBooks offers a password reset at their website if you have a current backup. The page walks you through the process step by step. You will need to have your license number and also you need to verify that your contact information is on file with them.
Here is the link for the 2005 and earlier password removal:
https://dataservices.intuit.com/qbpassrm2/qb_automation.htm
Hopefully you have a current backup of the company - that is what they will use to remove the password.
Nov 26, 2008 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks: Pro 2005 for PC Logo
123 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
