Question about ViewSonic Hasu05f Ac / Dc Power Adapter Supply (equiv)
Viewsonic hasu05f repair
Is it possible to repair a ViewSonic Hasu05f Ac / Dc Power Adapter. Is there a simple fix like a fuse in the housing? Thank you! Jeff
4 Suggested Answers
SOURCE: Viewsonic VP181 power adapter barrel jack size
yes. it is a 5mm center hole
Posted on Dec 18, 2007
budmrtn
  • 11361 Answers
SOURCE: ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Dec 02, 2010
jryc32
  • 408 Answers
SOURCE: How can I get AC
You could find one at this site:
http://www.nextag.com/viewsonic-ac-adapter/shop-html
Please let me know if this washelpful and if it solved the problem! Good Luck.
Posted on Sep 10, 2011
How can I get AC DC adapter for ViewSonic VE510+? I stay in Malaysia.
Hi ,
The best thing to do is go to viewsonic web site and order it from them ,,,,,,ship anyway ..Roy
Sep 10, 2011 | ViewSonic VE510+ (Metallic) 15" LCD...
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Where can I buy Dmtech AC Adaptor HASU12FB - Currys no longer stock the part
You might want to try a HASU05F. They are the same voltage, current, and connector and run cooler.
Aug 15, 2008 | Televison & Video
Need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
May 26, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
AC/DC Adapter
Hi, You would need an adapter that puts out 12 Volt DC, Output Current: 3.3 Amp and the Center Positive Power Tip (Output Power: 40W). The original ViewSonic adapter is M/N: UP06031120A Hope this be of some help/idea/ Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic Hasu05f  Ac / Dc Power Adapter Supply (equiv) Logo
54 people viewed this question
Top ViewSonic Home Security Experts
Lawrence Oravetz
Are you a ViewSonic Home Security Expert? Answer questions, earn points and help others
