Question about Motorola Mobility V31 RAZR GSM Cell Phone, Gold Cellular Phone
My gold Razr3 will not turn on with a new battery or charger
Phone will not turn on. I tried buying a new battery and using the charger. It has never been dropped before. I started using a Jawbone 2 earpiece about two weeks before this happened, if that has anything to do with it. Any answers? I have had the phone for two years in May. Cingular will not let me upgrade even though I have been with them for more than 12 years.
  • 23 Answers
Im sorry ihave NO idea how 2 fix this....
Posted on Jan 26, 2009
My phone won't charge. Got new charger and still will not charge
If your sure the charger is the right one and works,1 take the battery out and cleaned it and the compartment with a dry cloth giving it a quick vaccoum wont hurt to remove any dust. also the metal connections should be a light gold coloor if they are blackend they are worn/ burnt out. youl be better of either replacing the battery or buying a new phone. (see below)
2 is the slot where the charger connects clear and clean... give it a quick go with the vaccum to to remove any dust..
Failing that that take the charger back to the shop with your phone if the shop is anyway decent they will test both the battery and phone to see where the problem is
Jul 22, 2014 | Samsung Cell Phones
Screen is black all the time, can't turn phone on or off
1) Is your charger / adapter working OK ?
Most of the time, an adatper or charger contains a red or green LED, showing it's active, when inserted in the wall-outlet (110 / 240 V AC). In some cases, this LED will emit light, only when the mobile phone is connected.
If this doesn't happen, you might consider buying a new(er) charger for your mobile phone.
2) Is battery charged ?
No further discussion / c;arification needed.
3) Does phone contain an old(er) battery ?
If the mobile phone is used for a longer time or used intensely, the battery might be "worn out". A battery is able to be charged, but will show it's limits, because of it's maximum usage. With this I mean, they can be charged a maximum amount of times. If you even use a quick-charger, the battery may suffer more, resulting in a less longer lifetime. In such case you can replace your battery, by simply ordering / buying a new battery for your mobile phone.
Sep 03, 2013 | Motorola Mobility RAZR V3
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Samsung Captivate Galaxy S (only a month old) is dead... after having been charged overnight. Pushed "wake up" button, top right and NOTHING! What to do?
TURN YOUR PHONE OFF AND BACK ON OR TRY INSTALLING NEW BATTERIES!
SOMETIMES THIS REBOOTS YOUR PHONE!
YOUR CHARGER MAY ALSO BE DEFECTIVE, DRAINING YOUR BATTERY, TRY USING A CAR CHARGER TO RECHARGE!
IF NON OF THESE WORK, YOU'LL HAVE TO REPLACE YOUR BATTERY, GO TO A BATTERY STORE LIKE INTERSTATE BATTERIES OR BATTERY'S PLUS, THAT WILL BUY YOUR OLD BATTERY AND WILL INSTALL A NEW ONE!
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Samsung Cell Phones
My mini phone will not charge or switch on
First, the battery is drained, therefore any effort to turn it on will turn out abortive. Connect the charger to the phone and leave it for about 30 minutes to see if it will charge. If it does not charge then it means there is a problem.
The problem is most likely from either the charger, the battery or the phone. You need to diagnose each of them to know where the problem is from. To diagnose them you need to test them on other devices in order to know where the problem is from. First test the charger on another phone to know if it works. Then insert the battery into another phone and try to charge, remember the battery is drained and need some minutes to boost before indicating a charge, then finally, try another battery and charger to know if it will work.
Which ever does not work of the charger and battery need to be replaced, but for the phone, it is the connection port that need to be fixed if it does not work.
Thank you for using fixya
Caseytech
Jul 01, 2011 | Cell Phones
Unlock razr3
You don't, your phone is GSM, Verizon uses CMD, a gsm phone can not work on a cmd network.
Feb 18, 2010 | Motorola Mobility RAZR V3i Cellular Phone
New battery will not work
you most likely have "overcharged" your battery, or your battery isnt working... Buy a new battery
Jun 30, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Nokia 1100 not charging
Sounds like either a bad battery or bad charger. If company wont replace and you definately want to use this phone...buy a new charger and see if thats the prob...if not, try a new battery using the new charger. If neither solves the prob you have 2 choices... 1. Send to Nokia for repair or 2. Chunk it and buy a new phone. Good Luck!
Jan 24, 2009 | Nokia 6300 Cellular Phone
Phone will not take charge
I have the same problem with my phone i really don't know what is going on~!!!
Sep 03, 2008 | RIM BlackBerry Pearl 8100
LG scoop not charging well
The problem is your charge port on the phone. I've already had to have mine replaced and my daughters due to this issue. My girlfriends son had this phone to and has had his replaced twice already.
It is not entirely the charger! The problem is the phone port. The rep at alltel told me this phone is the most problematic phone they sell due to this issue!
Have the phone replaced under warranty if its under a year old, otherwise hope you have your insurance!
Other things to consider before having it replaced:
Backup your contact list! They cannot transfer it for you to the new phone when the port is bad and you cannot save your contacts to an SDcard either.
If you have any music, pictures etc, get the microSD card and back them all up to that so that you don't lose them either. Just don't buy the card from alltel, they want twice as much for it as you can get it for from Walmart/BestBuy etc..
Hope this help any of you out here from experiencing the pains that I've gone through with it..
Jun 14, 2008 | LG VX8300 Cellular Phone
Motorola Mobility V31 RAZR GSM Cell Phone, Gold Cellular Phone Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
