Question about Nikon D50 Digital Camera
AF area mode problem
My D50 AF area mode is normally set on Dynamic area, but if I switch to M, A, S, P or any other setting, when I go back to Auto the area mode is now set to Closest Subject. I have to go into the menu and reset it to Dynamic area every time I use Auto. I am also finding that the flash pops up and fires even in bright sunlight. I have to set it to no flash to prevent this, every time I turn the camera on.
  • Anonymous Nov 25, 2007
    What is the best mode to use. Single area, dynamic, or closest subject? I shoot with nikon.
I had the same problem and just changed the setting on both the camera and an attached lens to 'A' (from M) and it enabled those menus in the custom settings.
Posted on Jan 10, 2009
  • no51 Jan 10, 2009
    Problem Solver:
  • 7 Answers
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Posted on Jul 27, 2007
SOURCE:
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
How to get several focus points in a d7000 viewfinder?
Hi, On the D7000 you need to press the button on the side of the camera that's in the middle of the AF/M switch and then you use to switch to decide whether it's in 1 point autofocus (hence forth called AF), 9 point dynamic area AF, 21 point dynamic area AF, 39 point dynamic area AF, 3D tracking AF or auto area AF. If you need more help with switching AF modes let me know and I can help you out =)
May 16, 2011 | Nikon D7000 Digital Camera
Nikon D50 will not auto focus.
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Aug 27, 2009 | Nikon D50 Digital Camera
Wrong icon when selecting dynamic area
The D40 Dynamic area focus starts on the centre AF area then moves the focus to follow the subject.
The camera has followed something to the right and selected the right focus area.
This is normal.
You could select Single Area in the menu and move the area back to the middle using the rear AF Sensor Selector.
Jul 05, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikkon d50 wont auto focus
the D50 will only auto focus with an AF-S lens...make sure you are using an AF-S lens.
Also, check the swithc on the lens is set to "A" not "M" ...
Also, in the menu, check you set the camera as autofocus, not manual focus
Jun 07, 2008 | Nikon Cameras
The auto focus is not working on my Nikon D50
I assume the AF/M switch on the body is set to AF as well? This has not been mentioned but the D50 has two drive systems for AF.
Feb 25, 2008 | Nikon D50 Digital Camera
Memory buffer error - r07
Hi all - I know its been some time for this thread, but it helped me! When I pressed the shutter release I would hear a high pitch winding - thought it was the shutter and almost took it in for repair. Saw solution #5 - turned the AF switch on the lens to manual and back to auto - took care of the problem completely.
Jan 02, 2008 | Nikon D50 Digital Camera
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
135 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
