Question about Acer Aspire One D257 Netbook
On startup, the computer keeps saying it needs a startup repair, but will not move past that screen. It just goes back to the startup repair screen.
Does the motherboard need replacing? I cannot run a diagnostic or anything because I cannot get past the repair screen.
  • Acer Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
or it could be a virus or malware
Hope this helps.
Posted on Jan 20, 2013
leecom72
  • 4806 Answers
SOURCE: Boot/Startup repair problem
Microsoft updates do it again!!!
while the PC is booting up his F8 repeatedly, if it lets you into the sub menu boot into safe mode and perform a system restore, take the computer back to before you did the updates, if this works and your computer is restored, turn the automatic updates off
kind regards and please don't forget to vote
Posted on Dec 12, 2008
htechie
  • 146 Answers
SOURCE: Startup Repair Problem
GoTo:
All Programs > Accessories > System Tools > Schedule Tasks
Then...
1. Right Click on Startup Repair. Click Properties.
2. Deselect "Enable".(It is given at the bottom of the properties dialog box).
Posted on Aug 23, 2009
LaptopExpert
  • 458 Answers
SOURCE: my aspire suddenly wont load anything.screen goes
Yes, It Will Install And It Will Load Default Drivers, You Might Need To Still Get A Few Drivers That Vista Doesn't Recognise...But Again, It Will Still Fully Install...
Posted on Dec 01, 2009
  • 8909 Answers
SOURCE: Acer aspire one AOA110 tries
Possible hard drive errors I would say.
Try and start it from your restore disk or your System disk and back up your data them replace the hard drive.
Hope that helps.
Posted on Nov 29, 2010
crok41
  • 621 Answers
SOURCE: Acer Aspire 5534-At first I was having a problem
I would forget about all the recovery options if you dont care about lost data get ya windows disk and boot from that then format and reinstall the lot. If you dont have a windows disk download 1 free from http://thepiratebay.org/ cheers and please vote
Posted on May 18, 2011
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
Advent roma 1000 will not start up.
Hard disk drive has failed. Replace it.
Mar 03, 2017 | Advent Computers & Internet
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
Acer Aspire 5534-At first I was having a problem with startup repair. My computer would not startup. So I did a startup recovery and that didn't work, then I tried to return the computer to the...
May 18, 2011 | Acer Aspire 55345410 Notebook
Acer aspire one AOA110 tries to start up but keeps looping back to the startup screen. Goes throught a lenghty disk check and goes back to startup screen.
Hope that helps.
Nov 29, 2010 | Acer Aspire ONE AOA110-Aw Netbook
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
run in safemode Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Sep 22, 2010 | HP Pavilion dv2000t Notebook
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Blue Screen
When the computer first boots up, press the F8 key when the eMachines logo is replaced by the first Microsoft screen, then select Safe Mode from the list. If the computer will not boot in Safe Mode, you will need to boot from your Windows CD and select the repair installation option. If you can boot in Safe Mode, you will need to find out what is causing the system to reboot during startup. With the msconfig utility, disable all unnecessary startup programs and services, then try restarting the computer normally. If this works, you need to use the msconfig utility to add the startup programs and services back one-by-one until it fails to boot again (to locate your troublemaker). Keep repeating this until all services and programs (except the one causing the problem) are back in the lineup.
Jun 01, 2009 | E-Machines eMachines Desktop PC
Acer Aspire One D257 Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
