Question about LG WM2688HWM TROMM SteamWasher
Some display lights are not working
Some of the display lights are out, making it impossible to know the amount of time left in a cycle
  • Robyn Greiwe
    Robyn Greiwe Jan 20, 2013
    Some of the lights are working and some aren't, like I can't tell what the amount of time left inb a cycle because parts of the number do not light up, for example: I can't tell if it a 7 is a 7 or a 1
  • Robyn Greiwe
    Because the numbers do not fully light up, you can't tell if a 7 is a 7 or a 1, or if a 4 is a 4 or a 1,
  • LG Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Possible there is moisture within the board or the panel/display. remove and use a dryer to warm, reset checking for moisture in the harness and connectors. If the fault persists , the processor/display unit is a suspect.
Posted on Jan 21, 2013
443433 Serial number, value, year made?
Impossible to ID any bike by serial number alone, let alone assign a value without knowing condition, amount of original parts, etc. Do a little work yourself - Google "(brand/model) serial number" (without quotes) or at least tell us what kind of bike it is. See my tip:
How to determine the year value etc of your bicycle
Aug 25, 2017 | Cycling
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Washing cycle timer display slows/stops
sound like the pump is at fault still it might still work but it sounds like its an earth fault with the pump but some time by replacing it don't all ways work its normally the board at fault as well an expensive job OK
Nov 03, 2012 | Whirlpool AWOE8748 Front Load Washer
Heated dry cycle light on
see the cause and fix it:God bless you
Failure Code Condition Check/Repair "L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
Jul 21, 2012 | Maytag Quiet Series 300pan Dish Rack...
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
IPhone display light problem: My iPhones display light is no longer working. It randomly works from time to time however if I hit the home button to display my keylock it does not light up thus making it...
Try to factory reset the iPhone with the latest version 3.0 on iTunes and see if that helps if not then its a hardware problem and not the software issue.
Jul 27, 2009 | Apple iPhone 3G Black Smartphone
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
No Lights on Display for Indesit Washing Machine
did you check your breaker box?can you unplug and replug it in to reset itself?also you need to put a surge protector on it,it me know what you find-mike
Oct 15, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
