Black box covers television picture
When i turn on my TV i get a large black box that covers much of the screen ,you can see a little of the tv around the edges and also hear the tv. My satelite company thinks it has something to do with closed caption , I don't know how to turn this feature on or off ,if this tv has such. This box usually comes on after a few minutes and somtimes i can get it to go away by turning the tv on and off, sometimes it will stay off for seconds of several minutes.A couple of weeks ago it would just start changing channels on its on and i couldn't get it to the channel i punched in, that hasn't happened for awhile. is my tv dying, can you help? Deb
Called a TV repair store, got info over the phone for no charge and the TV is now as good as new. You should tell folks about the charge straight up, I wouldn't mind paying for a service but think you should advise at the onset.
Posted on Jan 28, 2009
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
May 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black Square area on Screen
If you press display on the remote, it will go away. It will come back, it's a common fault for this set and theres a mod to be done to the eeprom.
Apr 24, 2009 | JVC AV-32120 32" TV
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
A solid black block covers majority of screen - all else works
Try turning off the text box function of the closed caption decoder.
Sep 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Black screen
I have a Sharp Tv that had the same problem with a large brownish or black square right in the middle of the screen. It only left about an inch around the edges that you
could see the picture moving in behind the big black block or square.I have DISH sat-elite and the book recomending that I check and see if the "caption settings" were on
or off. They were on. I turned the caption settings off and the large square diappeared.
Nov 18, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
