Question about Schwinn 250 Recumbent Bike
Schwinn 250 Units setting
Will not go to Change units mode to set KM or Miles. When holding up/down arrow keys during powerup, it goes to "set load".
  • ernesto cuadra
    ernesto cuadra Jan 22, 2013
    many marks+ and models the console has BATTERIES, please try if your model has batteries, donwloa the instr manual www.fitness.manualsonline.com and donwload for free. and do the I did explain before. God bless you
    Top Expert:
  • Schwinn Master
  • 12,223 Answers
Replace the batteries by new ones. and clean the contacts batteries very well.
2) adjust the Reed switch, see the diagram, test for open or fulty, clean it, and tight the conector v. well.
However you must to back to the display are small orifice, Use the point o eraser pens, and click the small switch for to change. the Km or miles or vice. versa.
Posted on Jan 21, 2013
  • John Wolfe Jan 22, 2013
    There are no batteries, it has external power. It is not a treadmill, it is a recumbent bicycle.I am trying to call Schwin.
  • ernesto cuadra
    o.k but has a REED switch,please download your instr manual go to www.fitness.manualsonline.com and see the steps. God bless you
Change from km to miles on a chrysler 300 2013
On your steering wheel, you will see on your left some arrows (up, down, right direction), push the right arrow and change the settings from KM to Miles
Sep 30, 2016 | 2013 Chrysler 300
I WANT TO CHANGE KILOMETER TO MILe
Hi There,
Give this a try....go to Sportsmith.net and/or google Service Menu Life Fitness 95Ti. Once in the service menu, there should be an entry for the user to select Miles or Km.
It mentions pressing/holding the Pause Button until the Service menu appears on the display. Good Luck!
Apr 25, 2016 | Life Fitness 95Ti Treadmill 95 Ti
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
2008 mercedes benz 350 e class how to change odometer from miles to kilometers
Use the steering wheel buttons, bottom left one till you get to "Settings" then UP arrow, then use the +/- on the right side till you get to "Instrument" or "Display" (depending on model) Use the arrows till you get to "Display units in miles / km" and use the + / - to change same. Escpae using the bottom left button.
Nov 14, 2010 | 2008 Mercedes-Benz Mercedes Benz R Class
How do i reset the equalizer of pioneer car cd player?
  • 1Press the "Src/Off" button until the Pioneer CD player turns off.
  • 2
    Press and hold the "Src/Off" button again until the clock displays in the unit screen. In some Pioneer units, hold the "Multi-Control" button until "Clock Set" appears in the display.
  • 3
    Press the "F" (Function) button on the front of the CD player. In some units, press the "Multi-Control" button again to enter the setting mode.
  • 4
    Touch the left or right arrow buttons, or "Multi-Control," to select the segment of the time you want to change (e.g., hour or minute).
  • 5
    Tap the "Up" and "Down" arrow keys, or turn the "Multi-Control" button, to scroll through and select a number for that field. For example, if changing the hour to "2," scroll up or down until you get to the two. Use the right arrow to scroll over to the minute segment of the display. Use the "Up" and "Down" arrow keys to select the numbers that make up the appropriate number.
  • Oct 01, 2010 | Pioneer Audio Players & Recorders
    How do you reset the service warning light on a Sportcity 250
    When the vehicle is started and right after the ignition check, if there are less than 300 km (200 mi) left
    to the next Service, the specific icon flashes for 5 seconds. Once the service mileage has been reached,
    the icon remains steadily until the Service is reset.
    The warning light can be zero set even if the mileage is lower, up to 300 km (200 mi), compared with
    the Service mileage. During the 300 km (200 mi) before the service warning light comes on, the light
    flashes 5 times each time the key is set to ''ON''.
    The light should turn on first at 1000 km (625 mi). Successive times are strictly at 10000 km (6215 mi)
    20000 km (12430 mi), etc
    RESET
    Hold the MODE button down.
    Turn the key to ''ON'' and wait 10 seconds.
    During this operation the service icon flashes.
    Good luck,
    Alex
    PS-Don't forget to vote me, thanks!
    May 07, 2010 | 2007 Aprilia Sportcity 250
    Can't change computer from KM to Miles
    Hello there. To change the console from metric to english use this procedure.
    With the safety key out, hold the start button down while reinserting the safety key. release the start button. Then press the speed up arrow one time. You should see the screen change from an R or RN to an E.
    Remove the safety key and reinsert it normally and you should be ready to go!
    Good Luck! Tim
    Jan 13, 2010 | Exercise & Fitness
    I have bought a Tom Tom 950 and can not change the time. I like to change to 24.00 as well as am - pm. How do I change from yards and miles to meters and km. I have the userguide and service4 guide but...
    Hi Annette, I hope all tomtom units are the same, try main menu, change preferences, and click the blue arrow two times, you sould have the set clock on the top line, once you are happy with your setting press done and then click the blue arrow another two times to reach the set units, Top left, again when you are happy press done, I just hope the tomtom one is the same operations as yours, Colin.
    Jan 03, 2010 | GPS
    How do i change my forerunner 305 from kilometrs to miles
    Hit Mode till you see settings- (arrow down to Settings and press enter)
    Then General (enter)
    Arrow down to Units (You hav to arrown down 7 times) (enter)
    You will see Metric.... change it to Statute. (enter)
    Nov 20, 2009 | Garmin Forerunner 305 GPS Receiver
    My X300 navman sport tool has changed from kilometers to miles
    1. Press-and-hold down the button with the 'Dot' - allows access to configuration options
    2. Press the 'forward triangle' button repeatedly until the screen reads 'Set units (km/h) - or mph
    3. Simultaneously press the Dot & Forward triangle buttons - allows you to edit settings
    4. Press the Dot button to select the units of your choice
    5. Simultaneously press the Dot & Forward triangle buttons to accept changed settings
    Mar 17, 2009 | Navman Sport Tool X300 GPS Receiver
    Schwinn 250 Recumbent Bike Logo
    132 people viewed this question
    Top Schwinn Exercise & Fitness Experts
    Steve
    David Payne
    David Payne
    Matt Olenzek
    Matt Olenzek
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
