Question about Hardware & Accessories
I need to programming my outsider timer - Hardware & Accessories
  • 5,089 Answers
Jan 2013
1) Copy following link to help identify timer, and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
2) Add comment and describe timer in detail.
Posted on Jan 20, 2013
HI,I installed a GE digital timer model 15313 about two years ago.Now cannot turn on or off manually or program it. But it does turn on and off the times I programed the last. Thanks
Try reset and reprogram
If functionality is not restored, then replace timer.
Note also the load rating for each timer.
If you are operating above or outside the load parameters for timer, then timer might not function correctly or function as long as expected.
This timer, and most timers have 1 year warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15313
Suggest replacing with 5-year warranty Ei600
Can operate any load value, LED fluorescent incandescent motor
Has dawn-dusk or programmable mode
http://waterheatertimer.org/Programmable.html#st01
Gene
Sep 02, 2014 | Hardware & Accessories
How do you override the timer if you want to turn off or on outside the preset timer programme
1) Is this the Towerchron QE2?
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB instructions.pdf
2) Page 8: While slide switch is in run-own-program or run-preset-program mode, you can override by pressing select button until arrow points to Boost, or arrow points to ADV.
This will reverse program until next set point.
3) Add comment and describe which timer you have.
Jan 29, 2013 | Water Heaters
Why is Utilitech wall timer making lights flash?
You have connected white and red wires together.
White wire must be connected to neutral or to ground to operate timer mechanism, display and switching.
Copy following links to see correct wiring for Utilitec timers.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 30, 2012 | Hardware & Accessories
I have a double switch box controlling inside lights and outside lights. I installed a GE Smart Digital Timer (model 15086) to control the outside lights. In the wall box, the white wires are tied together...
From the description you gave on your post , sounds like you hooked the timer up correctly . Again , from the panel the hot ( black ) is jointed with the blacks feeding the inside switch and the timer correct ? And the Neutral ( white ) is jointed feeding the inside lights and timer for outside correct ? And from the timer ( GE model 15086 ) the Red Wire ( Switch Leg from timer ) is connected to the Black ( Switch Leg ) feeding the outside lights correct ? If this is exactly how you've wired your timer , then you have done your homework . Now all you need to do is make sure you have programed your timer correctly , and with your instructions that came with the timer , this should be no problem . If you continue to experience trouble , my suggestion would be to return the timer . It's not unheard of for some of these timers to come from the factory defective . This wiring configuration should not affect your inside lights . I hope this helps your home wiring project . I'm an electrician if that's any consolation !
Feb 09, 2011 | Hammering
The timer flashes, "no-op". Refuses to turn
no-op means 'no operation.
The manual says last resort to revive non-working timer is RESET timer.
This action will delete current day setting and all programming
Hold down ON/OFF and use paper clip to push in reset button for 2 seconds.
Release reset button but keep holding ON/OFF button down until INIT flashes on screen
Then release ON/OFF button and 12:00 should display.
At this point, timer can be re-programmed.
Simple step by step shows on following link:
http://waterheatertimer.org/ST01C-program.html
If timer will not accept programs, or operate after RESET, then timer has gone bad.
ST01C comes with 1 year limited warranty.
Most in-wall timers have same limited warranty.
Replacing timer:
-Advantage of ST01C is timer does not need Neutral wire to operate, and wiring can be simple.
-If you are using ST01C for 3-way switching, then easiest thing is to replace with same timer.
-If you are using timer as astronomic dawn-dusk, then replacements include EJ500, Utilitec 0192773, Aube T1034, T1070, T1072, T1073.
-If you are using timer for 7-day operations then there are numerous options:
http://waterheatertimer.org/Programmable.html#Aube
Jan 08, 2011 | Intermatic Inc. ST01C Digital In-Wall...
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a intermatic ej351 in my garage to turn the outside coach lights on and off. I made the mistake of putting some 10 year bulbs in the coach lights and now the red light on the timer just flashes...
I answer questions for free.
I specialize in timers and electrical devices
Below is the manual for the EJ351
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The red light is a good indicator of the EJ351 timer.
The manuals says that you can clear all programming by moving control lever to OFF-CLEAR position for 20 seconds.
After programs are cleared, the red light will turn off.
Then move control lever to ON position, and then red indicator light will start flashing.
So the problem may be that the timer programs were accidentally cleared.
Use the instruction manual to re-program your timer.
Add a comment if you need more assistance, and I will help.
Nov 02, 2010 | Intermatic Timer E1020, Single pole/single...
How do I forward calls to an outside number on a panasonic kx-ta824 system. what is the line access code
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Oct 06, 2009 | Panasonic KX-TA824PK Phone
Instructions on how to program the Intermatic EJ351C
take a look at this :
-or -
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
hope this helps
Jun 03, 2009 | Intermatic Programmable 24 Wall Switch...
Hardware & Accessories Logo
35 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
