Question about Maytag Neptune FAV6800AW Top Load Washer
Manual for removing tub - Maytag Neptune FAV6800AW Top Load Washer
    Sergeant:
  • 291 Answers
There is no manual that will show you how to do that. But there are now lots of YouTube vids that show step by step how to perform most procedures. Here's one on replacing tub seal that should help you.
http://www.youtube.com/watch?v=lmdfaoQLMy8
Posted on Jan 20, 2013
Can I remove the front part of the tub from the drum if I support the drum?
sorry but what model, My brother in law did something similar with a Kenmore, left tub in place to replace a slip roller in the front.
my clinker was stuck under a fin inside the tub
May 18, 2015 | LG Washing Machines
We just got this washer from a friend and there is a bunch of paper inside the tub that won't rinse out. How can we remove the tub to clean it?
Don't think the tub can be removed with any ease!
Best thing to do is fill with warm water let it soak and try to remove the paper first. Finish running empty after removing as much of the paper that you can.
Oct 22, 2013 | Haier washer RWT400AW User Manual
Dead mouse behind drawers. how do you remove drawers?
Open the drawer.
Top tub : depress the right hand tub clip and push it back about 30mm. Repeat for the left hand side.
Bottom tub:
remove the toe kick (refer section 9.4) and lower tub cowling (refer section 9.5), both optional.
1. If the cowling has not been removed, then the tub clips need to be pushed back about 130mm so the slide clears the cowling when the tub is lifted.
2. Lift the tub off the slides and push the runners back into the product.
3. Releasing the wire from the centre clip on the link assembly allows the tub to be moved further from the chassis (optional).
4. If the tub is being turned over for servicing, rotate it counter clockwise, remembering to remove the baskets first. Removing the handle will prevent it from being damaged.
5. Refit in reverse manner.
Aug 18, 2013 | Fisher and Paykel 23 in. DD603H SS...
F1 off balance how do I balance my bravo washer, to get it back on balance?
Their could be objects between the tubs, remove the inner tub nut under the agitation device and lift out the tub. look for objects in there. Also the inner basket has a balance ring in it.
Service manual and failure codes
Jun 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
The washer cycle stops with 26 minutes remaining in the cycle and will not drain the water
Can you lay the hose on the floor and get water to come out? If not then ya themobilian_2177.jpg
might have a problem with an object blocking the pump. To get into the machine
remove the whirlpool emblem in the front and you will find a screw. Remove it and the top comes forward and up. themobilian_2178.jpgthemobilian_2179.jpg
Raise up on the front panel after removing screws, the base has clips like a dryer.
The tub is suspended on four rods like a ge washer. Remove the drain hose and unplug the motor, the tub comes out of the case
It is not very hard to work on. You could have something between tubs.
This one had a big old pillow case between tubs
I have the service manual HERE and more photos HERE
Apr 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Model #WFW 8300 SW01 (noise in drum on high speed-sounds as if it has a chain or something inside rattling. How do we get a manual or parts book?
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LEAK @ TUB BEARING NEED TO KNOW HOW TO REMOVE AGGITATOR
Hello shortschip, See this Post and I think it will get you started (old nickname dh1200s). I believe the FAV6800AW/FAV9800AW use 6207-2rs bearings in the outer tub. I have not replaced so I can?t say for sure. The Service Manual which will take you thru removing the outer tub and Clutch Pulley to remove the spinner assembly. There is a special tool needed to break loose the ¾? nut to remove the Spinner Assembly. I heard of someone removing that ¾? nut with a impact tool. Let us know how you make out The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference. Check ebay for the bearings. Rich
Oct 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leaking Frigidaire FWS445RF
First suggestion,
if your not qualified to do this, i'd suggest you take it to a service center.
Removing the tub requires specialty tools, and adjustments that are crucial to working properly. It can actually be leaking from somewhere else. This can also be quite expensive, as most repairmen will not replace old parts once they are disassembled. Please weigh the cost of replacement, vs. fixing this one. If you decide to tackle this job yourself, get a manual. http://laundry.manualsonline.com
Good luck..
Jay
Oct 04, 2009 | Frigidaire FWS445RF
Hot tub intake cover removal
if there is no screw which there usually is u can try to unscrew counterclockwise
Jun 21, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
E20
Could you hear if pump is working ? Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port.
Nov 19, 2006 | Zanussi ZWF1230W Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
