Question about Iomega TV With Boxee 1 TB - HD Network Media Player
My Iomega TV with boxee is stuck. No picture, cant reset, blinking front light.
Solid blue light on, but green blinking light constant. Tv no screen picture. It like in the coming on mode, just stuck in a loop.
you need to reset your DVR. Push the center button in and hold it until it turns off and then turns on again. Let your tv reset it will take a few minutes just be patient.
Jul 08, 2015 | Televison & Video
Driver for iomega tv with boxee
My friend has the same and he downloaded this one: http://filebandit.net/download/3270/UyNzJhNmQz . The survey is to prevent viruses, but it's worth it.
Dec 21, 2012 | Iomega TV With Boxee 1 TB - HD Network...
Why does my Boxee consistently freeze?
Hi Cory, this definitely sounds related to the firmware updates that Boxee pushes out every so often. You'll be fine in no time.
First go and grab a computer and download the most recent firmware update from Boxee's website. Now go and copy the file on a USB flash drive and power down your Boxee box while keeping it plugged in. Following that procedure, press and hold the power button for 10 seconds until the device turns on. You will then choose to enter Recovery Mode and select "Update From USB" in order to download the most recent version of the firmware.
Still no luck? Leave your device turned on, enter the "Settings" menu, select "System", and go to "Advanced". Now you can clear away the Media Info Database and resolve any issues you may be encountering with scanning problems.
If it's not yet working it's time to enter "Recovery Mode" and do a hard factory reset. To do this, you will select "Reset All Settings" and then select "Factory Reset". This will wipe your Boxee of all its data, forcing you to update the firmware via the USB flash drive procedure we mentioned above.
Mar 13, 2012 | D-Link Boxee Box
My firmware update on my Boxee messed up the device
The good news? This is the worst problem the Boxee has and won't cost you much of anything in terms of time.
The bad news? No bad news! The Boxee rules!
Your first step is to download the most recent firmware update from the official Boxee website to your computer, saving it on your hard drive. Following that, insert a USB flash drive, copy the file, and power down your Boxee box while keeping it plugged in. Following that procedure, press and hold the power button for 10 seconds until the device turns on. You will then choose to enter Recovery Mode and select "Update From USB" in order to download the most recent version of the firmware.
If that does not work, leave your device turned on, enter the "Settings" menu, select "System", and go to "Advanced". From there you will be able to clear the Media Info Database and resolve any issues you may be encountering with scanning problems.
The final (and least desirable) fix is to enter back into "Recovery Mode" and perform a hard factory reset. To do this, you will select "Reset All Settings" and then select "Factory Reset". This will wipe your Boxee of all its data, forcing you to update the firmware via the USB flash drive procedure we mentioned above.
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
I have a IOMEGA Screenplay Pro HD 1 TB drive. It was all working fine on TV and PC. But suddenly after I used it with my PC for transferring files, I switched it off and then connected it to the TV. Now...
have u tried the tv sys button on the remote ? reperat a few times as it cyclels thru the formats. or the source button. first disconnect the usb
-will power
Nov 13, 2009 | Iomega ScreenPlay Pro MP3 Player
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Iomega TV With Boxee 1 TB - HD Network Media Player Logo
160 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
