Question about Zebra LP 2844 Thermal Printer
Zebra 2844 won't print anything.
LP-2844-Z... Installed 2 days ago for postage label printing. Worked fine until I moved it to another location on my desk (disconnected cables for move), during which the 5A -250V fuse in the power supply blew. Replaced fuse yesterday, powers up fine - but now, it won't print anything at all. Green light is on, and pressing the button advances labels fine. All connections are solid (connected via USB-A to Centronics Parallel Printer cable) and drivers have been deleted & reinstalled. Troubleshooter has been unsuccessfully run three times.
I'd really appreciate any help here. Thanks, and God bless you.
    Problem Solver:
  • 7 Answers
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Posted on Jan 29, 2009
SOURCE:
Label splits
because if label lengh is ex. 20mm and you set up label print area as 21mm, it will over the size and it will skip the next one. the print area shoul be less than the label length. please verify software or driver.
Jan 22, 2014 | Zebra LP 2844 Thermal Printer
Is it my pc or my zebra printer?
Go into printer options and select "Fit To Page"
Sep 07, 2017 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 prints a blank test page
possible was reset to factory defult and the darkness is to low, press the button until flash 5 times and let run untill see the dark print. then press the buton again. Try to print again (flash 1x)
outher possibility is the ribbon in on other way.
other possibility is the labels need to use ribbon (Thermal Transfer), and the printer is run out from ribbon.(run as Direct Termal.
Aug 17, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 is stalling out on every print.
Maybe the printer is not getting a good calibration on the label. If the status LED is a steady RED when trying to print, then the printer thinks its out of labels. A manual calibrationi could solve that.
1. Turn the printer off
2. press and hold down the FEED key while turning on the printer.
3. keep pressing the key until the status light flashes once, then let go
4. The printer will auto-calibrate for the size of label and then should be ready to use.
Press FEED once after its done and 1 label should feed.
Hope that helps !
Apr 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
Feb 21, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
2,400 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
