Question about Pride Health & Beauty
Pride Elite Traveler Plus occasionally stops and flashes eight times. Turning off and on corrects for a short time.
Pride Elite Traveler Plus occasionally stops and flashes eight times. Turning off and on works for short time and then repeats. I am not doing as the owners manual suggests might be causing the problem.
  • Pride Master
  • 1,263 Answers
Hi, right it normally one of two things:
1. the connection to the rear axle, remove rear axle and clean the four connectors, gently, make sure there is a good contact.
2. The connection of the battery pack to the frame, again clean and make sure there is a good connection.
Regards
Posted on Jan 21, 2013
2 Suggested Answers
HoverTech
  • 232 Answers
SOURCE: Where can I find a
Contact Pride Mobility at 800-800-8586, they are usually around $20.
Posted on Nov 09, 2010
Why does it move a few inches, beeps six times, and stops?
hi Kathy ,,,
that fault is related to the throttle pot , if possible have a look under the throttle, you will see a cross head on the stem,
it should be situated dead centre...
Regards
Rob.
Nov 19, 2015 | Pride Go-Go Elite Traveler Plus HD - 3...
How do I get my gogo elite traveler plus hd to engage the brake when parked on an incline?
Hi Scott, the brake itself could be failing or the other issue could be the controller itself or simply a bad connection (hopefully), so check the connections from the brake to the controller
Regards
Rob
www.gewizrepairs.co.uk
Jul 29, 2014 | Pride Health & Beauty
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
Needing to replace free wheel mechanism go go elite traveler scooter
em, this is new to be , can you go into more detail of the actual problem ?
Nov 28, 2012 | Pride Go-Go Elite Traveller Plus HD...
My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Where can I find a repair manual for a Pride GOGO Elite Traveler Plus?
Nov 06, 2010 | Pride New Mobility Victory XL 4 Wheel...
Whats the difference between the taveler plus and the traveler plus HD other then 25lbs. The specs look the same and the weight is the same
Well you got it the difference is weight capacity the HD will support 25 more pounds than the plus Hope this helps
Oct 13, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Health & Beauty Logo
116 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
