Hp 6040 not able to copy but prints ok display shows copier disabled check copy control device
Checked everything in adminisrator, machine had finisher on but i have disconnected it it will print any report and comes to ready, but will not copy
  • 86 Answers
SOURCE: Unable to send a print job to the device.
i know what your problem is phone 07764303923
Posted on Feb 14, 2008
  • 35 Answers
SOURCE: cannot copy or fax - Canon i-sensys L140
CHECK THE ADF
IT IS JAMMED OR NEEDS TO BE REPLACED!
CHEK AGAIN ..EVEN THE TINNEST PIECE OF PAPER CAN JAM IT.
Posted on Jun 09, 2008
technotech
  • 183 Answers
SOURCE: my HP deskjet F380 is showing E
Try this :-
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Posted on Jul 17, 2008
POCBM
  • 121 Answers
SOURCE: HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Posted on Mar 22, 2009
c_robertson
  • 123 Answers
SOURCE: prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Posted on Apr 29, 2009
How to make Konica Minolta copier online?
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use. Mite also check to make sure you have the right drivers for the machine.
Sep 03, 2014 | Konica Minolta bizhub Office Equipment &...
We've been having issues with our office printer. Yesterday we had to restart the machine due to it not printing when we selected a job from our computer. Today, I was making copies and it said "Err
the hp 4345 is a very reliable piece of kit they suffer generally from the fuser swing plate and ADF mylar failures. if you can give me some more details I.e. we had to restart th machine due to it not printing- has the machine been allowed to come to ready? if so is it possible to take a simple copy from the glass ? if it comes to ready and is able to make a photocopy and your still not able to print then the error lies between the IO card and your computer. try reinstalling the printer driver if that is the case. please when giving information about err??? please include all characters seen on the display an example fault code would look like error 59:00 with a possible expansion code of 0c00340021 these are the important details that tell the engineer which part in the machine is being reported as failed without these details you may as well just say my printer aint working whats wrong with it ( Actually that is exactly what you said).
Jan 15, 2014 | HP LaserJet 4345mfp Printer
Will not print
try to restart your computer. before u print something, make sure u select the right printer (maybe there's copy 1, copy 2, and so on), check the usb cable, and don't turn on your printer before the laptop/pc ready because your computer will not able to detect the printer if you turn the printer first.
Jun 13, 2012 | HP Photosmart 4180 All-in-One Printer
Blank pages when making a copy. The printer cartridge is fine. I can print demo, configuration, usage reports, etc. from the Reports menu.
Is it coming on ready mode? check scan also in same manner..open adf unit verify weather light is glowing in CCD?.. if no replace CCD..
Sep 05, 2011 | HP Laserjet M2727nf Multifunction Printer
My printer will not print from my computer. It shows the scan, photo ,copy screen and will do those things. It shows that it is connected to the computer and everything looks like it will print, it just...
Check that the printer cable is connected properly to your computer and printer.
If they are ok I need to know what printer you have as alot of HP printers are having formatter board problems that will cause this.
If the cables are ok and it is not a HP printer, or even if it is, you need to try re-installing the printer driver. Delete your old driver and install new driver.
Jun 02, 2011 | Office Equipment & Supplies
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
How to hard reset a 1312nfi
This reset will change user and network settings Before performing this reset it would be advisable to print some information pages to retain any settings that you might want to restore.
Configuration Page
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Configuration report, press OK.
Menu Structure
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Menu Structure, press OK.
Network Report
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Network Report, press OK.
After printing these reports it will be safe to perform an NVRAM initialization to hard reset the product. Follow these steps.
1. Turn the machine off.
2. Press and hold the right arrow and cancel (x button) while turning the machine on.
3. Release both buttons when Permanent storage init. is displayed.
Once finished resetting the machine will return to Ready.
Jun 16, 2010 | HP Laserjet CM 1312NFI Color Printer
Every time a fax tries to come through my cartridge jams up.
CAN YOU MAKE A COPY ON YOUR FAX MACHINE...DOES THE COPIED PAGE PRINT OUT.???
REMOVE YOUR CARTRIDGE AND MAKE SURE NO PAPER IS CAUGHT. TRY TO PRINT OUT A REPORT OR SETTINGS LIST FROM YOUR MACHINE.
May 18, 2010 | Office Equipment & Supplies
We keep getting an error code 344* when we are trying to transmit a fax. What can we do to fix this?
Error 344 means :-
The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
Solutions :-
  1. Attempt to send the fax again when telephone-line conditions have improved.
  2. If the fax session was using error correction, disable ECM.
To disable ECM Press :-
  1. Press Setup .
  2. Press the Down arrow (c00326489.gif ) repeatedly until Advanced Fax Setup displays.
  3. Press OK .
  4. Press the Down arrow (c00326489.gif ) until Error Correction Mode displays.
  5. Press OK .
  6. Press the Right arrow (> ) until either OFF or ON displays.
  7. Press OK .
  8. Send another fax to verify that the ECM is enabled or disabled.
Check the Phone Cable connected with the printer.
Make sure the Cable should be connected to line 1 port at the back of the printer and it should be going directly from the printer to the wall jack and not to the Serj protector.
Try to print a fax test page.
  1. On the control panel of the product, press the Setup button (c01361401.gif ).
  2. Press the Right Arrow button (c01185072.jpg ) to select Tools , and then press OK .
  3. Press the Right Arrow button (c01185072.jpg ) to select Run Fax Test , and then press OK . The product displays the test results on the control panel display and prints the Fax Test Report.
Now Do this :-
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Consult the user manual that came with the product for proper setup and configuration. Try the above steps and let me know if it works for you.
May 10, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
106 people viewed this question
jasbo
jasbo
