Question about Onkyo TX-NR709 A/V Receiver
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Posted on Nov 15, 2008
SOURCE: My Onkyo Receiver TX 601 is turning itself off
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
Mar 05, 2016 | Onkyo Audio Players & Recorders
We would like to assist you. Please follow this link an supply the requested information to verify that your unit qualifies: http://www.onkyousa.com/Support/service_info.php .
If your unit qualifies, a box and prepaid shipping label will be sent out. Please note that as part of the repair process, the firmware will be upgraded and all user settings will be reset to factory defaults. The average time for repair is 7-10 business days after the unit arrives at the service center, Thanks, JT
Oct 18, 2014 | Onkyo TX-NR709 AV Receiver
Sep 07, 2014 | Onkyo TX-NR709 A/V Receiver
Apr 11, 2012 | Audio Players & Recorders
Jan 31, 2011 | Onkyo TX-SR674 Receiver
May 25, 2010 | Onkyo TX-SR605 Receiver
Apr 01, 2010 | Onkyo TX-SR702 Receiver
Apr 09, 2009 | Onkyo TX-SR701 Receiver
May 06, 2008 | Onkyo TX-SR605 Receiver
Nov 09, 2007 | Onkyo TX-DS838 Receiver
82 people viewed this question
