Question about Garden
Need Diagram of Fuel Tank for 2090 Case Tractor
The Fuel is not running properly at times it seems like something is blocking if from going to the fuel pump, would like to remove the drain at the bottom of the tank but need the diagram to know if that drain is screwed in and what is inside whether it is screen or something else
psds4
  • 293 Answers
SOURCE: How TO REPLACE A IN TANK FUEL PUMP ON A 2000 gmc jimmy
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800a13e9
hope this helps
Posted on Oct 11, 2008
  • 8 Answers
SOURCE: ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Posted on Feb 21, 2009
rockitman187
  • 2559 Answers
SOURCE: No fuel getting from fuel tank to fuel pump
It has a screen filter inside the tank that may have gummed up.If you drain the gas and look inside the tank,You will be able to see it.
Posted on Apr 05, 2009
  • 3600 Answers
SOURCE: 1994 Toyota Pick up 4X4, fuel pump only works when starter is run
The information you are requesting is copy writted in order to get it leaglly go to alldatadiy.com and buy a subscription to your car and you can view all the informantion you want. and the diagram shows all the information you need includeing a powertrain harness and look up by system not in a book.
Posted on Aug 26, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a service manual for a John Deere
If you can find your model and type numbers on the engine, go to www.briggsandstratton.com put in your numbers and it will locate the IPL for you.
IPL = Illustrated Parts List
Posted on Sep 18, 2009
Testimonial: "The engine model and type numbers were listed in the op manual. The problem is solved. Thanks!"
I have husqvarna yth1542xp runs about 5 minutes then shuts off. iblew thru gas line towards tank seemed like something was in line or tank. started and it ran another 5 minytes or so and same thing...
Try it with the fuel cap loose ( not off just loose). This will see if the tank is venting properly. You may also have a bad fuel filter, fuel lines or trash in the tank.
Jul 01, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Case 7130 Tractor stas running then quits
I had a close to that problem and decided the fuel was the problem,So I added a electric fuel pump between the fuel tank and the manual fuel pump,,but also check the fuel line between the fuel pump and the fuel tank,for it may plugged with dirt or the manual fuel maybe to weak to the job ,so I added electric fuel and the no more problem with air locks or no fuel to keep the tractor running.
Jun 04, 2014 | The Times Case Corporation Tractors...
John Deere LX188 fuel mixture or choke problem
Try slackening the fuel filer cap to make sure there is not a vacum building up
May 30, 2013 | John Deere Garden
Lawn tractor run fine with full tank of gas but runs ruff, and acts like its running out of gas when fuel level drops below 3/4 tank. The problem has gotten progressively worse over the last few...
hi there FIXor Destroy
have you checked and tried running tractor with the fuel tank cap loose or off in case its not venting
and stopping fuel flow , have you checked for debris in the carb and main jets / emulsion tubes and air bleeds ? if it has a fuel pump is it working properly ?
are you sure the valves dont have tight clearances ?
is the tank getting alot of vibration , may be getting vapour loc from fuel agitation in the tank, or some kind of heat transfer from the engine to the fuel
take a look
cheers pauly46
Jul 02, 2011 | Craftsman Garden
2090 case trasmission problems
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
Jun 01, 2010 | RTO Case W14 1570 2090 2290 2294 2590 3594...
AIR IN DIESEL FUEL LINE
It be probably in the tank,check the pipe that goes inside the tank.
Nov 16, 2009 | The Times Case Corporation Tractors...
I have an 18 HP Craftsman tractor (model 917255980) that will not start. If i remove the fuel line from the carb, gas does not run out freely, hoever, by applying suctin on the line gas does flow breifly....
The pump is not good,to test it,you take out the out fuel pipe start the engine ,see if fuel is coming out fully to the pipe,if sometimes it comes and cut,this means the fuel pump is not working properly.You have to change it.
Sep 06, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
8050 LOW POWER
Take a closer look there should be a fuel transfer pump located on the block usually between the primary and secondary filter. If this is not the case you are on the right track about a possible leak (air) You can try and pressurize the fuel tank ( about 20 -30 pounds ) and check for leaks. but be careful not to use to much air pressure because to much pressure will seal off the leak and it may not show
Aug 14, 2009 | RTO Allis Chalmers Tractor 8010, 8030,...
My tractor stalls like it is starved for gas although the gas tank is full. I,ve changed the fuel filter and the gas cap. I've cleaned out the gas tank, gas lines, and the carburetor bowl. The problem...
I had a similar problem with a sears tractor. close to the carbarator is a rectangle box with a rubber hose going to the engine block - remove the hose and spray carb cleaner in the hose wait a few mins and try again - its a vacuum for the carb
Jun 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
