Runs 10 minutes and cuts off - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Possible that there is a circuit trip or that the timer is shutting down due to loss of contact. clean the timer and try once again, use WD40 and blown jet air into to clean of dirt accumulation.
Posted on Jan 21, 2013
I have a 2005 chevy impala with a v6 engine and when im sitting idle it cuts off after running for like 10 minutes
Does the car run well otherwise? Does it have the get up & go like when it was new? Does anything odd/funny occur in the minutes just before it cuts off?
Dec 10, 2014 | 2005 Chevrolet Impala
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
Craftsman 18.5 hp, 42"cut, riding lawn mower quits running after 10 minutes
ONE OF OR YOUR COIL PACK...(UNIT PLUG WIRE COMES FROM IS PROBABLY DEFECTIVE
Jul 29, 2012 | Craftsman Garden
My AC unit runs for 15 minutes the cuts off. Then there is no
Hello, if there is a condensate safety switch this will cut off power to the tstat if the comdensate line is backed up. Check the condensate line to make sure it is clear.
May 06, 2012 | Heating & Cooling
Husqvarna riding lawn mower yth 2448 cuts off as if running out of gas after 10 - 30 minutes
Mine would run for about 15 minutes and die. I pulled the carb off and thoroughly cleaned it. Inside the float bowl there is a plastic device held on by two phillips headed screws. Under this device are two tiny tubes with small holes in the side of them. Make sure these are clean. I used carb cleaner in a spray can and a tip cleaner. Make sure to wear eye protection if you use spray cleaner. I reinstalled the carb and, so far, it is working fine.
Apr 08, 2012 | Husqvarna Garden
I have a yamaha tdm 850 1992 model, it runs and startds fine and does not miss a beat. over the last day it has started to cut out completely at freeway speeds. it will do approximately 10 minutes fine...
Because of the higher voltages run in bikes nowdays to meet fuel regulations,spark plugs are often a big problem.Drop a new set of plugs in .It's the easiest and cheapest place to start.No dealers to rip you off.If this is not the problem,it would suprise me.Hope this helps
Aug 31, 2010 | 1999 Yamaha TDM 850
Runs about 10 minutes 7 cuts off. can't restart
Plan your beer breaks every 10 minutes and enjoy the time off. Also check your fuel mix, the engine is running hot, replace fuel mixture with proper oil mix.
Jul 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Toyota celica cuts out
check fuel pump pressure. change fuel filter.
Mar 18, 2009 | 1992 Toyota Celica
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
