Question about Logitech QuickCam Orbit AF Webcam
Estar Pan Af - Logitech QuickCam Orbit AF Webcam
  • Logitech Master
  • 27,725 Answers
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality. Hope this helps.
Posted on Jan 20, 2013
My 2001 grand cherokee has the engine light on, the coolant is alwasys running low, and I have a evap leak
evap leak can just be a bad, gas cap or not tight. and is not an issue here. its just a tank vent.
the loose is serious
the collant called AF, (antifreeze ) can only go a few places.
1: to the ground.
2: to the passengers does, heater core leak.
3: to the oil pan, did you check oil for AF contam?
4: to the A/T pan, did you check the A/T dip stick for contam?
5: to the exhaust tail pipe tip, called STEAM.
find the the path and problem is obvious.
if all 4 dont pan out (pun intended) then use the 2 rad tests.
got oil in the AF, filler neck, on cold start, before start, off the RAD cap and look , got oil there?
does the rad leak down test fail> (a tool)
does the green/blue tester fail, (exh. gas in RAD found)>>>>>????
does a compression test fail,?
does a cylinder leakdown test fail..
all are simple tests.
Mar 17, 2014 | 2001 Jeep Grand Cherokee
Need to fill coolant reservoir every day with antifreeze, check engine light on & flashing
The flashing light means there is a problem with the engine serious enough to damage the catalytic converter. You should get the computer scanned for trouble codes.
If there are no external coolant leaks, the engine is probably burning the coolant thru the cylinders and out the tail pipe. Which could also be causing the flashing light.
Mar 04, 2014 | 2007 Suzuki Reno Hatchback
02 civic 1.7 overheating problem
lots of causes. but symptoms and tests are first.
is it leaking AF? antifreeze
is AF on the ground.?
in the oil pan? chocolate, milk shake?, same with A/T transmission./
is it just the gauge, telling you that? or
steam shooting out the rad cap?
or engine pinging, and CEL glowing. >?
loosing fluid level? each day?
1: cold engine, open hood , RAD cap off, AF is way low or gone there? oops this is real loss, side overflow tank, is not a clue to level, now. only actual rad. fill.
Jan 07, 2014 | 2005 Honda Civic 1.7i
Suzuki water pump 1992
did you do the fall Radiator fluid AF, check to see if the ratio is
still 50% ? tool costs, $2 and takes $2 every end of summer.
did you. if not you risk cracking the engine block in half. or head or both or more... yes, more.
1992 what what car. a sidekick, or esteem? ?????
my guess is this is the 1992 G16a TBI engine, with 8 valves.
water in the engine pan , not water in the A/T pan?
here is ONE, and why
2 young grils move car from Florida way up north, and boom.
oil looks like milk shake.
http://www.fixkick.com/engine/97-motor-pull/HTML/image_1.html
Dec 24, 2013 | Suzuki Cars & Trucks
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Dear Sir, I have bought a dvd recoder RDR GX 380, but i cannot tune my tv with RF Output cable.
Se o cabo esta ligado na saida RF do DVD a TV deve estar sintonizada no canal 3 ou 4, e a sintonia deve ser executada no DVD. Para usar o tuner da tv normalmente o aparelho de DVD devera estar desligado.
Dec 13, 2010 | Televison & Video
Engine starts then cuts off after a few seconds
SI ES CON MOTOR A GASOLINA PUEDE ESTAR ENTRANDO EL SENSOR POR FALTA DE ACEITE O PUEDE ESTAR TAPADO EL CARBURADOR
Oct 06, 2009 | Honda Garden
I need to repair a tv philips LO1.1UAC-7638
tu problema puede estar en la fuente hace poco me encontre con una tele igual y le encontre el filtro de 47 a 160 aparentemente bien pero al quitarlo para medirlo estaba con una pata mala pues no hice mucha presion y se desprendio ojala te sirva este filtro esta en la alimentacion del horizontal que estes bien
Feb 09, 2008 | Televison & Video
Auto focus mode
One Shot AF will focus on something and stop the AF process. One Shot AF will not fire the shutter until the lens is in focus with something. This AF mode is available in some PIC modes, like Macro mode, I think. AI Servo AF will not lock the focus, and if the subject or the camera moves, the camera will continue to seek a sharp focus. Servo AF will allow the shutter to fire whether in focus on not. This is mode only available in the Sports PIC mode. AI Focus starts out in One Shot AF, but if it detects subject movement it switches to AI Servo. It does not switch back to One Shot unless you release the shutter button and start over. This mode is available in P, Tv, Av, M and probably some PIC modes. The DRebel defaults to the AI Focus in most modes but switches very easily into Servo. Much easier than any other EOS camera I've used. In fact, too easily for most people. For example if the camera locks focus and you them move the focus manually (only on lenses with FTM), or sometimes if you zoom, or even pan the camera; all of these can force the camera to switch to Servo when you don't really want it to. The Wasia (Russian) firmware hack can force the camera to stay in One Shot, but it can't force the camera to start out in Servo.
Sep 14, 2005 | Canon Digital Rebel / EOS-300D Digital...
Logitech QuickCam Orbit AF Webcam Logo
27 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
