Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Clean condenser coils
Condenser coils are cylindrical and I want to clean all sides of coil. How do I get to back side of coil?
    Novelist:
  • 159 Answers
Its not easy but a flexable vacume hose would help. and aslo you can take the end peice off and try to get it from the inside to. Good Luck
Posted on Jul 18, 2007
SOURCE:
Kenmore Elite series side by side refrigerator serial # 79571033010
Probably low on freon(which means a leak) or a blockage in sealed system. Both costly repairs.
Dec 03, 2017 | Kenmore Refrigerators
12 year old GE ref side by side both sides warm
has cleaning the condenser coils helped out? does the condenser have a fan? if so when the compressor is running it should be running also. is the compressor hot to touch?
May 20, 2014 | Refrigerators
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Service manual
Having the area around the door getting warm is normal but getting hot may indicate a defective condenser fan motor or the condenser coils have become blocked with dust. You are going to need to unplug power, pull your refrigerator away from the wall, remove the front kick plate and the rear cover on the back of your refrigerator to get to the condenser coil and fan just to see what is going on. If the fan is not running strong when plugged in then there may be a problem with the=> 61005323 Condenser Fan Motor Above is a video that will help you on cleaning the condenser coils. If you think there is a problem with the fan motor and would like my assistance please let me know. As for a service manual I don't believe there is one for your model number. I do have a manual that is basically the same thing if you like? Thanks Sea Breeze
MZD2766GES
Jul 11, 2013 | Maytag MZD2766GES Side by Side...
Hot side panels
Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Apr 24, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
Excessive condensation dripping inside refrigerator
Bonjour,
Some refrigerators have heaters mounted in different places around the unit to take care of condensation. If those heaters don't work, you see drips. Another common cause to much frost/ice build up on the freezer evaporator coils or in the area beneath, below or around the evaporator coils. That's usually a sign of incomplete defrost cycle. Another cause could be broken or shifted insulation that's letting very cold air get to the back side of a partition that has warmer air on the other side. The warmer side drips condensation.
Based on the condenser coil cleaning results and not having any temperature data. In your case I would guess incomplete defrost. That leads to defrost timer, defrost heater, defrost termination thermostat and clogged evaporator drain line. Or some combination of the four.
Jul 11, 2012 | Frigidaire Refrigerators
Is it normal for a side by side to have the inside panel between door get extremely hot? the woman i bought it from said it was normal to help seal the gaskets to keep the doors closed. Anyone hear of...
if the middle where the doors close is hot clean the condenser coil and make sure the condenser fan is working,hopefully all you'll have to do is clean out the condenser coil,remove the front kickplate and then pull out the fridge and remove the bottom back panel,make sure the fan is blowing then with a shop vac vac up any lint you can from around the compressor and the condenser coil,then you can set it to blow and blow out the coil to get all the dust and lint out of it.hope this helps and good luck with your machine
Oct 15, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How do you clean the refrigerator coil on a whirlpool side by side model #ed5kvexvb00.
condenser coil ? remove bottom grille use long condenser cleaning brush available at most hardware or bldg. supply.
Dec 10, 2010 | Whirlpool ED2GHEXN Side by Side...
Pressure keeps dropping on my jaguar boiler, no leaks in house but hot water coming from overflow outside
hi In most air-conditioning systems, the condenser unit is located outside the house and is prone to accumulate dirt and debris from trees, lawn mowing, and airborne dust. The condenser has a fan that moves air across the condenser coil. You must clean the coil on the intake side, so, before you turn off the power to the air conditioner, check to see which direction the air moves across the coils. Here's how to clean the condenser:
Step 1: Cut down any grass, weeds, or vines that have grown around condenser unit; they could be obstructing airflow.
Step 2: Clean condenser with commercial coil cleaner, available at refrigerator supply stores. Instructions for use are included. Flush coil clean (do not use hose); let dry.
Step 3: Clean fins with soft brush to remove accumulated dirt. You may have to remove protective grille to reach them. Do not clean fins with garden hose, as water could turn dirt into mud and compact it between fins. Clean fins very carefully: They're made of light-gauge aluminum and are easily damaged. If fins are bent, straighten them with fin comb, sold at most appliance parts stores. A fin comb is designed to slide into spaces between fins. Use it carefully to avoid damaging fins.Step 4: Check concrete pad on which condenser rests to make sure it's level. Set carpenters' level front to back and side to side on top of unit. If pad has settled, lift pad with pry bar or piece of 2-by-4, then force gravel or rocks under concrete to level it.
Sep 12, 2008 | Heating & Cooling
GE side by side refrigerator
Try pulling toe plate at bottom front and clean the condenser coils. If they are plugged, it will cause this to get hot. If you can't see coils in front remove back panel and clean coils there.. Give it time after cleaning to see if it helped. If no change, remove back panel and check to see if fan is turning when the compressor is on.
Also check for something caught in fan blade, such as a dead mouse or a dead coupon. If fan isn't turning, may need condenser fan motor. If still need help, give us a model number. Found in refrigerator compartment at top on side walls.
Nov 22, 2007 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
410 people viewed this question
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
