Question about LG WT5001CW Washer
My LG WT5001CW top load washer will not drain. All diagnostics indicate a pump problem. I took out the pump and tested it and it works fine. What else could be the problem?
    Sergeant:
  • 291 Answers
Shine a flashlight up the hose from pump to tub. See if you can see the light from inside the tub. Sometimes a sock or other small item can find it's way in there. Also make sure the impeller of the pump is straight and not cocked to the side, indicating a bent impeller shaft.
Posted on Jan 20, 2013
  • 4 more comments
  • mbiddinger
    mbiddinger Jan 20, 2013
    Thanks for the feedback. I had already tested the pump when I removed it...doesn't seem to be a problem. Also, I was able to completely drain the tub when it first became a problem and the water flowed freely. Somehow the signal to "pump the water" is not making it to the pump. If I rule out the pump as the problem, then I suspect that it must be a problem with the control board. Any other thoughts?
  • B.H. Countryman Jan 20, 2013
    Well i'm always skeptical when the control board is suspect. Make sure the drain hose to standpipe is not inserted too far and that the machine has not been pushed back restricting it's drain flow.
  • mbiddinger
    Thank you.
  • mbiddinger
    I reinstalled the pump and decided to test a small load just to see what would happen. It worked fine until it had to drain. I reached back and touched the pump with my hand and it immediately began to work.
  • mbiddinger
    I can conclude the pump is fine, the control board is fine. It must be a loose wire at the pump.
  • mbiddinger
    Should be an easy fix. Thank you!
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Posted on Jun 05, 2009
SOURCE: LG Washer LE Error
Solved LE error for my WM1832CW by replacing Hall Sensor. Bought part 5016501KW2002A for $Cdn 26 at Sears parts store. Thanks to TC at http://www.howtomendit.com/answers.php?id=28214 for instructions:
1 Open rear panel. Take 17mm nut off (it's the only one)
2 Pull off what looks like a goofy hubcap (it's held by magnets)
3 Unscrew the six 10mm bolts and gently lower the coils
4 Remove and replace the Hall Sensor (plastic comb looking thing)5 Plug in the sensor and re-install the coils and cover.
30 minutes for me.
Test spin cycle if desired by following chart on page 19 of service manual at http://www.appliancefactoryparts.com/content/pdfs/125448.pdf
(note lower models skip step 10 (heater test).
Hall Sensor Part labelled as K351 in diagram on page 41 of service manual.
Posted on Jun 30, 2009
SOURCE: lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Posted on Sep 06, 2009
SOURCE: lg front load washer WM2301 will not drain
drain hose may be bent or clogged, or the drain filter itself may be clogged
Posted on Sep 11, 2009
  • 82 Answers
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
Posted on Jan 22, 2010
How do I take the bleach dispenser out of my top load washing machine
The service manual does not indicate that the bleach dispenser can be removed at all.
Jul 18, 2015 | LG WT5001CW Washer
I have an lg washer model # wt5001cw i have a code le overload protection how can i reset this code
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
Nov 17, 2014 | LG WT5001CW White Top-Loading Washer
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
Washer displays Ld and won't drain. won't restart or anything. kenmore oasis
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem.
You can use a diagnostic test to start the drain pump. To start this diagnostic test, press the following keys in this order: SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL. The display should show "dt" after this key dance. Press the JEANS/COLORS key to start a 60 rpm spin and drain test that will terminate after 40 seconds. Listen for the drain pump. It should be running during this test. Also listen for unusual noises from the pump that could indicate that it is clogged. You may be able to drain the water from the washer using this diagnostic cycle depending on the severity of the clog or failure. If not, you may need to manually remove the water. If you are able to safely access and clear a clog in the drain pump or drain line, you may be able to repair this problem yourself.
Jan 07, 2011 | Kenmore Washing Machines
Lg wm1832 will not pump water out the dran pump is
If the pump does not work when power is applied separately, you may find, upon disassembly, that the impeller has disintegrated.
Mar 08, 2017 | LG WM-1832C Front Load Washer
Our calypso won't go through the full cycle it will either say, LD or ob? We tried evening the load then we took the close out and it still does it
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer Will not drain
if you have a multi meter, connect to pump terminals in situ and put on drain program. if no volts then points to a timer fault. if volts present, points to a blocked drain hose or faulty pump. remember you are testing with no load
Aug 28, 2008 | Frigidaire GLWS1233A Top Load Washer
LG WT5001CW Washer Logo
524 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
