Question about Bose Lifestyle 5 Music Center Ps3-2-1 Acoustimass Subwoofer & Cables 2 Speakers
How do you add more speakers to bose ps321
I have extra bose speakers and need to know how to plug them up.
SOURCE: Need to know the OHLMS rating for speakers
Hello! The impendance of the "speakers" does not be "minor" of the "system" . If your system is
3 Ohms, yours speakers must be 3 Omhs too, or 4, 6, 8... Use serial or paralel conectios. Ex.: 3 Ohms +3 Ohms in series = 6 Ohms ---- 3 Ohms +3 Ohms in paralel = 1,5 Ohms.
Sorry about my bad english, I'm just speak in portuguese.
Posted on Dec 19, 2008
  • 77 Answers
SOURCE: ps321 subwoofer
Yes you can wire it to anything but your going to loose power if the amp cannot handle it
Posted on Feb 24, 2009
SOURCE: Bose PS321 No Sound
The power supply is 29 volts raw voltage,the IRFI44N fet on the power board is used is a switcher.
It reduces the voltage to 17 volts which is required for the AV3-2-1 meda center.The higher voltage biases the sound to cut off and can blow the drivers,try changing the fet and see if plays........
Posted on Apr 05, 2009
cjackHD
  • 71 Answers
SOURCE: Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
Posted on May 31, 2009
  • 12 Answers
SOURCE: Can I add nonbose speakers to my Bose Lifestyle
Check this forum. Lots of good answers there:
http://homeavi.pro-forums.com/
Posted on Jun 21, 2010
I would like to add a turntable to my Bose Cinemate II but when i plug the RCA directly into the Bose module the volume has to be to the max and is still very quiet
You need a preamp to solve that problem, the older amps and receivers had built in phono inputs with a preamp stage. Radio Shack use to make a preamp that ran on a 9volt battery for turntables that ran into the very problem you are talking about. But I do not know if they are still available, go to www.ebay.com Type: turntable or turntable preamp
Apr 07, 2012 | Bose Cinemate Digital Home Theater System...
Need a power adapter forr Bose mediamate speakers
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you search type in the coorect details i can supply a link to an adapter but not sure if its the one you need
http://cgi.ebay.com.au/New-12V-AC-AC-Power-Adapter-Supply-BOSE-PS71-DCS91-/270684179832?pt=LH_DefaultDomain_0&hash=item3f0608cd78
AU $12.60 +AU $27.16
in the USA
hope this helps
Apr 01, 2011 | Bose MediaMate Computer Speakers
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
Bose ps321 checked everything have had for 6 yrs not getting power
It sounds like you most likely blew a fuse. Unplug it and open it, look around where the plug wire goes into the box. You should see a fuse, usually a glass cylinder with metal ends. If its blown, replace and you should be good. If fuse is good, let me know and we will go from there.
Sep 05, 2009 | Bose Audio Players & Recorders
I want to add the VCS-10 center speaker to an existing bose syst
the vcs is designed to plug straight into the reciever not the acoustimass.
Jul 19, 2009 | Bose VCS-10 Center Speaker
901's directed to TV
Yes, you can plug your TV directly into the Bose 901 Equalizer, but you will still need to go from the EQ into an amp to drive the speakers. The Bose EQ basically is for the speakers, not the signal coming in to it. Because of the speaker design, the EQ "shapes" the sound to compensate for the speakers. Please rate my answer, thanks.
May 22, 2009 | Bose 901 VI Main / Stereo Speaker
Adding Spaekers
Are you able to add speakers to the Bose GSX 321 system?
Jan 01, 2009 | Bose 3 2 1 GSX System
Ps321 subwoofer
Jun 18, 2008 | Bose 3 2 1 GSX System
Bose PS321 No Sound
Jan 28, 2008 | Bose 3 2 1 GSX System
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Bose Lifestyle 5 Music Center Ps3-2-1 Acoustimass Subwoofer & Cables 2 Speakers Logo
51 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
